Schmidter
- Mar 17, 2016
I have higher sound in one of the earpads. And different thickness of earpads. Should I try removing the foam and then return it if it has glue? What is your suggestion?
says so on the tech spec in the manual. http://cdn-downloads.tcelectronic.com/media/216585/tc_electronic_desktop_konnekt_6_manual_english.pdf
So if i were to say get a magni 2 amp, will the 80ohm output impedance matter when feeding into an amp? read this on reddit
"Output impedance of the DAC is not important when it connects to an amplifier. If the DAC has a low output impedance than you can power sensitive headphones without the Amp. With balanced armature IEMs that have large variances in impedance relative to frequency you want as low output impedance as possible to avoid the frequency response being affected."
i ask because i dont want to get the modi dac if i dont need to. the dac on this interface is really good for my productions.
sorry for going off topic
Thinking of getting a mic to use with mobile and for Skype. Any suggestions?
I have a pair of the glued pad stock and I had channel imbalance.
I have taken off the pad's and they were not glued the right way up on one side, I have re hot glued them back on and now the channels are balanced correctly.
I just want to add how good these things are, I am so glad I checked the pad's.
It's not the glue, read again. It was the one pad not being installed the correct way around.
How the glue can affect the sound like this? Can anyone explain this?
The vocals etc were coming from in front of my right eye and not out from the center of my nose.
There is a hole on the back of the pads that show where to put the pad and this was not aligned with the pin on the pad.
The glue is in the four holes on the ear pads you have to slowly pull them away so not to rip the material.
I would suggest to check only if you hear a balance issue and notice a pad being the wrong way up and if you have a hot glue gun to reattach the pads.
Question..
Do I potentially save £30 odd and buy a new pair off ebay from someone, or should I just pay £175 off Amazon with the option of returning?
I currently use HyperX headphones, so I'm sure this will be an improvement, but the whole Gibson thing is putting me off.
I'm second guessing whether to buy them!
