rgmffn
- Jul 15, 2015
The screws are attached to those rings. I am not talking about the big plastic gray colored screws that the speakers pivot on. Those are the ones that can't be removed. Look under the metal ring at the top, right where they are connected to the two metal rods of the head band. There is pair of tiny nuts under the top side of the ring there and all of the clamping force from the headphones is focused 100% on those two tiny screws. The metal rods go through those rings and underneath the ring is where the problem screws are. Its a leverage point and will most certainly come loose on many of these cans over time.
Many of you guys use different cans for different things. I am a one can man. I used these every day, and took them off many times each day. Less than a year, the left side became loose and that is the side that I grab the cans to remove them. The right side is still tight because I don't take them off from the right. I take them off from the left and set them down on top of my computer next to me to my left.
I'd be willing to bet that with frequent use many of these things come loose.
Ok, I see which screws you're talking about now. Mine are still tight. I could get a pair of small angled needle nose pliers on them (barely) and could possibly tighten them but it would be tricky. Something like these..
I would still recommend using two hands to remove the HPs. Using one hand like you describe puts unnecessary strain on that section. Especially the left side that you grab. This is likely why yours came loose.
