- Mar 20, 2010
If I was getting a closed headphone, I'd personally would put my money on the Shure 1540. That's just me though.
I've got the xl pads actually, haha. The m100s are punchy and fun to listen to, but don't really extend any deeper than the 650s, which is why I'm looking for something like the x2 or he400. Honestly, I'm pretty sold on the x2 though and will probably pick one up on amazon once they're back in stock.
MLE: how do the shures compare to the x2 purely sound wise?
Wow, wasn't expecting this. The x2s are looking like a solid choice.
Any suggestions? I haven't had much experience with closed back cans. I have a pair of vmoda m100s but the only time they get head time is when I'm at the library studying since they're so portable, but the 650 is on a completely different level. I've heard good things about the mad dogs, but I'm hesitant to try them due to the restocking fee on returns.
That's the downside of the 2 vs. 1 according to Tyll's measurements on impulse response... though those measurements are never perfect . I found the X1's pretty quick though, considering the thicker sound. My Q701's beat them, I'm sure.
The best closed headphone I've heard is the Focal Spirit classic. It goes well with the HD650 since it's mids are absolutely stunning! The bass os deep, strong it's on the warmer side of neutral. I also owned the 1540 but found them good sounding but it doesn't sound like it's price. A bit U shaped with slightly loose bass. It had good air too and a decent stage especially in Dolby Headphone. I think the classic is better hands down!Thanks for the suggestions, but I've tried both of the above and unfortunately they're both too uncomfortable for me to wear. The momentum's earcups are too small and the urbanites clamp too hard and I can only wear them for at most an hour at a time. Also, the momentum and urbanite aren't quite at the hd650/x2 level in terms of audio fidelity. Although I'm looking for a bassier headphone than the 650, I'd like it to sound better than a portable can since I'm only going to be using it at home-- I've got the m100 for portable use already, and I didn't like the momentum or urbanite more than the m100.
