yearsofwisdom
- Apr 19, 2010
After removing the pad (I can only remove one side), it appears the screen is depressed/ not flush. Is this problematic? Upper right
What I'd really like to know is whether:
1. only the x2s with glued earpads have sound quality issues, or if there are unglued x2s that also have SQ issues
2. all x2 with glued earpads have sound quality issues, or if only some of them do.
Basically how do I know if I have an X2 with SQ issues if I don't have another "good" x2 to compare with.
Just putting it out there in case someone somehow knows, or sees a solid trend.
Thx!
There are no sound quality issues. One dude on Reddit made that claim and now everyone is getting paranoid. There were dozens of pages with people getting RMAs and so forth and not one mentioned the SQ changing. I've had two X2s, one X2/27 with the sticker issue, another X2/00 with very slight glue and thinner pads - they sounded identical.
Unless someone can come forward with the drivers looking different, different measurements, SOMETHING to prove that there is a difference, don't take one fear-mongering guy's word for it. Instead look at all the people who have said the exact opposite throughout this entire QC ordeal: they sound the same.
Will check my box when I get home. I did a close inspection of the headphone itself when I opened them this morning and found nothing wrong with them. The earpads do have some glue residue where the polls that hold the earpads are located, but this is a non-issue IMO. Just wipe it off, it doesn't affect the quality of the product.
One of my glued ones came off pretty easily. The other one ripped the pad... I think it's time for a return? Agree?
I'll have to remove my other pad and check. If it comes off with relative ease like the other one, I think I'll be good. I'll just wipe the glue off with some goo-gone!
If mine ripped cause of the extraneous amount of glue, probably a good idea to return it right?
yes
yes sir
I just ordered a used one for $141 from Amazon Warehouse Deals. I hope they are good.
