m-p
- Aug 24, 2009
@Kun
You might have checked these threads but in case you haven't:
Top-Tier Universal IEM Comparison Chart, Frequency Response Charts, & Discussion (First Post Updated Often)
and
Impressions of the Ortofon e-Q7 versus the IE8, CK100, SE530, FX500 and X10 (plus CK10 discussion from post #120)
I only have the IE8 and have never heard the others you mentioned, but I chose the IE8 because I like their main sound characteristics: warm, have strong bass with sufficient mid & high as well as good clarity, great soundstage, and laid-back presentation, therefore, based on other members' impressions I would lean more towards the e-Q7 for you due to it not having the mid-upper bass hump of the IE8 as well as lower overall bass level and more forward mids, which suits female vocal and your preference (non bass head) better. I auditioned the SE530 as well and found that it is indeed mid-centric (in a good way), but I personally feel the bass and treble are quite weak and cannot keep up with the mid.
Instead of IE8, alternatively I would suggest the Monster Turbines Pro Copper or the wooden Victor-JVC HA-FX700 (which I recently ordered so haven't got it in hand yet), since they are described by other members as being able to reduce much of the IE8 mid-upper bass hump (with the FX700s having a bit more & deeper bass, more treble, and are more natural than the Copper Turbines), have better clarity, and more neutral, but still retaining pretty much of the IE8's warmth and other main characteristics.
Good luck with deciding!
and
