PC Enthusiast-Fi (PC Gaming/Hardware/Software/Overclocking)
Dec 31, 2015 at 5:52 PM Post #8,584 of 9,120
Do you have a source of any kind that provides a measurement of the RAM clearance of your case/cooler?
Your case will never be an issue, but usually the specs of the cooler or the reviews of it will tell you the RAM clearance. It also depends on the motherboard, as some motherboards are much more compact than others, though this is becoming less of an issue as it is much more standardized and long traces are bad anyways.
+1
Dec 31, 2015 at 11:39 PM Post #8,585 of 9,120
Anyone use an AiO liquid cooling solution?  I got the Corsair H90 but the water pump makes a racket.  Drives me crazy.
-H
Jan 1, 2016 at 1:17 AM Post #8,586 of 9,120
-H
I've owned the H110i, and the pump is almost completely silent. My only guess is that the pump/waterblock assembly is not quite secure, although I'd be careful about overtigitening as well. Make sure there isn't any cables hanging directly on the pump, and perhaps make sure that the pump isn't vibrating against a neiboring MOSFET or VRM heatsink. If you have skylake, it's possible that there's issues with mounting, seeing as Skylake processors are physically shorter in height.
Jan 1, 2016 at 3:43 AM Post #8,587 of 9,120
H110i GTX here, and the fans on silent mode make more noise than the pump...
Belated edit, just ran a passmark test for my PC - summary here
Further edit, might as well throw in a 3DMark result as well... Not too bad on a single card.
Jan 2, 2016 at 5:42 PM Post #8,588 of 9,120
  I will soon. I looked at the trailers and gameplay on youtube, and it seemed so much fun. I will try far cry series. are they any good?
If you liked Far Cry 3 the you'll probably like Far Cry 4. They aren't serial so you don't have to had played the previous ones.
It's fun and will keep you entertained for 12 - 20 hours most likely. The game is more focused on gameplay, exploration, and doing schiit then story.
-H
I have an original H50, no issues for the past 6 years or so
Jan 2, 2016 at 10:30 PM Post #8,589 of 9,120
Thx, guys.  I called Corsair and they are sending a replacement.  Apparently, it's a known thing and some water pumps do exhibit the rattling issue.
Cheers.
-H
Jan 3, 2016 at 12:47 AM Post #8,590 of 9,120
Cheers.
-H
I've heard good things about Corsair support! Nice to hear they are doing fine still
Jan 3, 2016 at 1:01 AM Post #8,591 of 9,120
Doing some client builds this winter. Check them out
Computer #1
CPUIntel Core i3 6100 3.7GHz$125.00
MotherboardASUS H110M-A$49.00
RAMCorsair Vengeance LPX 16GB$40.00
PSUCorsair CX430M$25.00
WindowsWindows 10 Home
CASEZalman T5$29.99
SSDSamsung 850 EVO 250GB$81.61
Hard Drive1TB WD Blue 7200rpm$55.00
Total $405
Computer #2
CPUIntel Core i3 6100 3.7GHz$125.36
PSUEVGA 430W1 80+$29.99
CASERosewill Micro Mini SRM-01$29.99
Total $410.95
Mini Desktop Stations (2x)
We also bought two Lenovo Thinkcenter M73 Tinys speced at:
CPUIntel Core i5 4590T 3GHz Quad Core
Hard Drive500GB 7200RPM
RAM8GB DDR3 1600MHz SODIMM
For $470 each. Note that these are extremely small and well reviewed.
For computer station #1, we bought two borderless 21.5" monitors
Lenovo LI2223s 2x for station #1
For station #2 and the two Lenovo Thinkcenters. They will be using each a 21:9 widescreen monitor. So bought 3 of these
Super excited to put them together. Will upload pics
Jan 4, 2016 at 2:39 PM Post #8,592 of 9,120
Computer #1
CASEZalman T5$29.99
[tr] [/tr]
Total $405
Computer #2
[tr] [/tr]
Total $410.95
[tr] [/tr]
You don't factor in the cost for Windows 10?
Jan 4, 2016 at 2:58 PM Post #8,593 of 9,120
Haven't bought it yet lol
I'm buying keys in the week.
Going to be buying two Windows 8.1 keys and then upgrade to 10. (Only need two keys for the two custom computers, the others come with it already)
And then going to be buying 4 Microsoft Office 2013 Standard keys.
The Windows 8.1 keys are $20 each and Offie 2013 Standard keys are $25 each which isn't that much
Jan 5, 2016 at 1:17 PM Post #8,594 of 9,120
Not Office 2016?  Is this a cost issue or is there something else?
Nice budget builds, too, but make sure the PSUs are decent, since not going with something OEM'd by Seasonic or Super Flower can bite you in the ass sometimes.  Also, are those 6100s OCable since there's no base clock restrictions, or do you need Z170?
Jan 5, 2016 at 3:38 PM Post #8,595 of 9,120
Yep costs plus availability for Office
I'm not getting garbage PSU units but at the same time I'm not dropping dough on full Seasonic platforms. PSUs are important but are pretty overblown in terms of how often fail or will mess stuff up.
I don't recall OC on those but its a client build. There will be no OC or worry about Z170 chipsets.
