PC Enthusiast-Fi (PC Gaming/Hardware/Software/Overclocking)
May 20, 2015 at 1:58 PM Post #8,041 of 9,120
Dang jaq-chan. Those are some great looking cables...how do you braid them?
And dang vant kun ...... Sorry for ur loss. The only right thing to do is to give it a military class burial....by lighting it up with some AKs and convincing yourself to buy a new htpc even though the other one still works
I don't have the mini B cable braid link on me right now but here's the camera strap :D
http://sonyalphalab.com/forums/showthread.php?560-Wrist-Strap
May 20, 2015 at 11:31 PM Post #8,042 of 9,120
Oh my gosh I'm so sorry :( can you still RMA it? But then you'd be out of an HTPC until they'll give a replacement... >.<
Good thing that it still works lol.
I'm not the type to RMA my stuff. If something breaks I either fix it myself or get a new one. This HTPC was a DIY build anyway, so even if it did break I'd just put an entry level graphics card in there.
May 26, 2015 at 11:09 AM Post #8,044 of 9,120
If only there was just a little more empty space in there; then it would be enough for my disappointment in this internal hardware layout.
May 26, 2015 at 12:56 PM Post #8,046 of 9,120
  My laptop runs pretty hot. The last time i opened it, i was barely able to put it back. It is not in warranty for some time. I think that opening it again might proove usefull for cleaning. I wonder if cleaning would give me a boost in any way?
Yes. Temps will drop. CPU will stop throttling. Replace your thermal paste too. Helped me personally.
May 26, 2015 at 4:47 PM Post #8,048 of 9,120
  ... i am not very..
I had not done this before with a computer or laptop...
Is it simple / can i screw it up badly?
What laptop is it exactly but yeah most of them are just screw in. I would recommend cleaning the fan when you open it, that's probably the only thing you gotta worry about unless you see dust everywhere so blow canned air on those too.
May 26, 2015 at 5:20 PM Post #8,049 of 9,120
Dell 15R/ n5010 - year 2010.
I opened it once and it was bad, i barely could put it back together, it was scary stuff.
I think that i would need to open it again, it gets hot and slow, I need more processing power for my project, and I must fiind a solution fast.
May 26, 2015 at 5:40 PM Post #8,050 of 9,120
Personally for a computer like that, I'd clean the fan or make sure it's not failing since that might be the reason it's hot. Then I'd buy more ram if you have free slots to speed it up, and reformat the computer OS & install the bare minimum of programs.
May 26, 2015 at 6:04 PM Post #8,051 of 9,120
I wouldn't worry about RAM.
If you can, clean out the thing and report back. Wiping the drive may help with speed.
May 26, 2015 at 8:08 PM Post #8,052 of 9,120
I found that upgrading to an SSD saw a major improvement in speed in an Inspiron 530s I had. Also good thermal paste helps with reducing the CPU temperature, and probably increasing the performance too. Replacing the original thermal paste with Arctic's MX-2 drastically reduced the stock cooler's fan noise.
Note to self: smartphone thermal pads do not make for a good CPU thermal solution.
May 27, 2015 at 1:27 AM Post #8,054 of 9,120
