PC Enthusiast-Fi (PC Gaming/Hardware/Software/Overclocking)
Jan 12, 2014 at 1:38 AM Post #4,037 of 9,120
Checked everything, and all of it worked except for them.
Well, yeah...
Did you have a rig to throw the cpu in to check? Not sure if it would have saved you time or not, if you RMA'd at the same place.
Jan 12, 2014 at 5:13 AM Post #4,038 of 9,120
Yay dude you're the only one here that has water cooling that ISN'T one of the wussy little corsiar closed loops! lol nice rig though.
His is the best, and certainly a system that makes me drool over with envy...but the ONLY one here? Something tells me I forgot to post what I put together over the last few months:
Yes, I'm aware of that one kinked tube. It wasn't kinked when I first put it in, only when I filled and bled the loop. Tubing can be a pain sometimes, and because I don't have QD fittings, I'm reluctant to drain and fill the whole thing again. Angled compression fittings on the Raystorm block would probably help a lot with the kinking problem.
I also apologize for the awful Galaxy S III camera quality.
Still, even with the maintenance involved and the fact that it's a HUGE money sink (still want QDs and compression fittings in general, and those add up fast)...I'm reluctant to go back. It makes working around the CPU socket area so much easier, and it performs a lot better, too...albeit not enough to keep the 4770K from hitting the throttling point under the Vcore required for 4.5 GHz or higher under Prime95 28.1 or LinX 0.6.5, so I keep it at a modest 4.4 GHz, 1.22V. Damn thing needs a delid badly. Stronger fans on that Black Ice GTX 360 might also help too (it's currently packing SFF21Fs in push because that's what I had lying around).
Someone elsewhere actually thought my 4770K was an awful overclocker just from only knowing it was 4.4 GHz and under water...well, it's still a lot better than that craptastic 4670K I started out with, but I'd probably hit 4.5 or even 4.6 GHz with ease if they'd just soldered the IHS on, I'm sure. But I can't bring myself to risk breaking that 4770K yet, either.
Jan 12, 2014 at 5:27 AM Post #4,039 of 9,120
Angle fittings man. Best $8 you'll spend if you water cool. My system is getting rather long in the tooth tbh. It kinda needs an update but there's still nothing really worth updating too. I suppose picking up a cheap i7 4770k and deliding it wouldn't be a bad decision. Might get 5Ghz outta that under my loop...if I don't crush it. Even WC isn't gonna cool a stock 4770k if you ramp it up, it's the stupid rubbish TIM intel are using these days. Gotta remove that stuff and replace it with something decent.
Jan 12, 2014 at 11:20 AM Post #4,041 of 9,120
Looking good Nameless, I would for sure fix the kink, Tygon is good stuff. Just throw an anti-kink coil over it and you should be good to go.
Jan 12, 2014 at 11:40 AM Post #4,044 of 9,120
Ouch. Does this price include GPU waterblock, CPU block, radiator, pump, etc.?
Yep. Full loop.
Tubing
Fittings
GPU block(or two/three)
CPU block
Pump (DDC or D5)
Rad (or two)
Reservoir
I dunno what price WC gear is in the US, but $200-$300 seems pretty reasonable if you pick up the rads/blocks/pump 2nd hand. Otherwise...maybe $300-$500 if you're doing a full loop.
Jan 12, 2014 at 11:53 AM Post #4,045 of 9,120
Yep. Full loop.
Tubing
Fittings
CPU block
Pump (DDC or D5)
Rad (or two)
Reservoir
Ah. Well, it was a concept for me. I don't have the money or experience in this area, but it didn't hurt to inquire.
Jan 12, 2014 at 1:39 PM Post #4,048 of 9,120
  True, but is it easy? Will a 13 year old (I'm relatively tech/build savvy though) be able to do it? What are the chances of the stuff leaking?
Fairly easy. I haven't done it but I've looked into it for awhile.
Also, there's a reason you do leak testing.
I don't get why people like compression fittings. They look pretty bad to me. The reusable hose clamps from Lamptron and Bitspower looks really clean though. Monsoon fittings are...okay...
Jan 12, 2014 at 1:49 PM Post #4,049 of 9,120
I don't like the look of the clamps. Prefer the perfect symmetry of a entirely round compression ring. Not too keen on monsoon fittings either. For me it's either barbs with extra tight hose (eg, TTL's builds) or compression fittings.
Jan 12, 2014 at 2:09 PM Post #4,050 of 9,120
I am with you. My last build was just barbs, very clean look.
