dcguy73
Formerly known as dc_guy
I will go on record here that the Pathos clips and distorts on certain tracks and recordings especially those with high dynamic range, should you feed it anything higher than the rated 4.4VRMS input.
My May outputs at 5.8VRMS on XLR and I thought I had a faulty unit which I had sent back to my distributor to verify and it was confirmed that the Pathos doesn't do well with higher voltages.
That said, I'm glad to have it back and it works fine off RCA from my May. While it was away, I had more time with my Studio Six. While it is a great amp in its own right, the Pathos has that layering of sound which I've only heard it do on any headphone system thus far.
It drives my HE6SE very well with room to spare as at 125 volume, it's loud enough for my musical enjoyment without harassing my wife next to me hahaha
Sometimes I get carried away and crank it up a bit and suddenly I can feel death staring at me haha
Thank goodness you posted this! I just reached out to Tim at Kitsune Hifi to see if it was possible to get the voltage adjusted so I don't run into the same clipping problem as you do with balanced connections. My Holo May KTE unit hasn't been built yet, so hopefully this is an option. I guess I'll find out...
