jonathan c
The choice of power cable, also, can make a difference in the HPA-1 performance.
I'm currently using an Isotek sequel, which is probably not going to get the best out of the amp. Which cable would you recommend ?The choice of power cable, also, can make a difference in the HPA-1 performance.
Well I'm using it with the Focal Utopia. It's possible other high end headphones might sound better with this amp, but I assume the Utopias will take full advantage of the HPA -1 's capabilities.Sorry if I'm stating the obvious but have you tried a different headphones? The difference in sound will be in several orders of magnitude more noticeable than anything else.
These are US makers: Audio Envy, Morrow Audio. I use these.I'm currently using an Isotek sequel, which is probably not going to get the best out of the amp. Which cable would you recommend ?
That's a silver plated cord? I'd try all copper. Likely provide more body and fill in the mids. I like Sablon stuff but that's getting into the weeds. Copper for starters.I'm currently using an Isotek sequel, which is probably not going to get the best out of the amp. Which cable would you recommend ?
I would think the caliber and specs of this amp should sound good with most headphones. Utopia certainly. But as always, comes down to synergy and individual preferences.Sorry if I'm stating the obvious but have you tried a different headphones? The difference in sound will be in several orders of magnitude more noticeable than anything else.
Let it warm up for an hour, then your good to go....anything more than this is not necessary.I recently purchased a HPA-1. I can hear its potential, but I'm just wondering for those who have owned one for a while, how long would you say it takes to sound its best ?
The HPA-1 will drive your Utopias to their full advantage...no problem...but remember gargbage in garbage out...you choice of music and its recording quality willWell I'm using it with the Focal Utopia. It's possible other high end headphones might sound better with this amp, but I assume the Utopias will take full advantage of the HPA -1 's capabilities.
Are you using a phone as source?Well, the sound is not really 'filled in' by that I mean I can hear the size and some of the depth of a recording, but it is only just audible. I can certainly hear parts of the recording I have never heard before on other equipment, however, again, it is on the edge of my perception. Basically, the depth, soundstage and detail in a recording are hinted at, but nowhere close to being fleshed out.
I have had it since April, but have not had the chance to burn in/use it much. I could certainly hear some improvement after the first month. However I recently renovated so my entire system was disconnected for two weeks. My suspicion is it really requires quite a bit of use before sounding its best, but I was hoping to hear what other owners have experienced.
Or a mediocre DAC
I'm using a CEC TL 51 CD transport feeding a Hugo 2 via optical.you using a phone as source
Hugo 2 being thin sounding but high res is your problem but it’s not easy to solve that problem. The easiest way to solve your problem is to get a better dac - by that I mean something like Weiss, Emm Labs MSB, dCS, etc. but that’s more money. The other solutions all involve various trade offs between size of soundstage and ”filled in” soundstage. I think in your case going used may be the best route given you are still using a CD transport - old Wadia, Mark Levinson, Audio Research, Sonic Frontier dacs from 20yrs ago for example. If you are willing to go USB Ayre QB9 Twenty should also do the trick.I'm using a CEC TL 51 CD transport feeding a Hugo 2 via optical.
Besides, it’s a Nelson Pass protégé design (directly under NP).Even though this is a 2016 timeframe amp, its still a TOTL amp and is a wonderful all around amplifier. Recently I bought a dac that has a TDA 1541 NOS Phillips chip in it from the late 80's and early 90's...not made anymore but still excellent and a legend. Its as good as my other 2020 version dacs...
Amps both tube and SS even hybrids are not that much different or better...dont let the 2016 date interfere with a decision for a HPA-1.
With time amps have better specs, it the THX stuff and many really high dollar tube amps...but the HPA-1 competes very well and is an honest great design.
People will tell you its big and costs alot and there are other "better priced" choices.
Thats true. Its is indeed big, and cost alot...but its built like a tank, and works like a amp should....handles a wide variety of impedance's and drives 99% of the stuff
out there well.
You can find one used for a lot less....and IMO its worth it....
Good luck with your search!
Alex
