At first, I thought you (edit: Napilopez) wanted to jump at me because I said that they sound "extremely natural to my ears." But then you said yourself, that "to some, like me, these have a very real sound signature."
I've listened to a lot of Michael Jackson in my past - from many many different sources. Of course I've never met him personally and sadly I've never seen him perform live, so I really don't know what his real voice sounded like. But my brain has decided that the average of the plethora of different voices will probably sound very similar to the real one. And the HJE900 just hit that voice which my brain says that it's the one!
The majority of head- and earphones just sound way too dark and warm to be real, my Zino are way too bright and thin and while the HFI-780 has the correct warmth (and sound very good), IMO, I do need the other recorded sounds in relation to adjust my ears to be sure it's the real Michael. When I pop in the HJE900, though, my head just shouts "that's him!" (The same goes for several instruments and other voices, too.)
I'm not even a musician, nor did I ever set foot into a studio, so please don't quote me, but for me, the sound of the Panasonic is just right!
On another note, I've tried out the L sized tips, just for fun. While the M sized tips are just barely large enough to completely close the ear canals, the L sized ones do remain comfortable but add too much of a seal. Isolation gets better but the bass is just overpowering with these - I really don't hope that Panasonic was aiming for that amount of bass!
So if you're searching for the right tips, I'd suggest to be careful and maybe go with a more lightweight tip than what you use on other earphones.
BTW, I like how these (both M and L tips) slide in effortlessly without building up any air pressure. I think this is because of the air vents and it improves comfort even more. I don't have to take out my IEMs anymore if I chew on something - great!
I also don't see any reason at all to perform a foam mod or to tame the highs. Not once did I found a tone to be harsh or too high - but maybe that's because I'm used to Ultrasone headphones...
Boy, look at me, I've become a fanboy! So now I have to mention something negative: the cable is too short, isolation is insufficient, bass is too strong (not with the correct tips), ... ... ah, the volume of the mids is recessed!
