cassull
- Jan 12, 2011
I recently installed a FM converter into my car, which did not have an AUX input for playing music from other devices other than the stock CD and tape cassette. I was originally using a tape adapter, the sound quality was pretty awful... Anyway, the FM converter sounds much better paired with my iPod classic than the tape adapter, but the volume is very low, even with the iPod volume turned up and the car volume turned up as well. I started looking into portable amps and have found a lot of information so far on Head-Fi, but I'm not sure what to get.
I'd considered some of the really cheap Fiio options, like the E6, but I thought I could spend a bit more for quality in case I use the amp elsewhere. So far, I've narrowed my choices down to the PA2V2 or the E11. The lower the price, the better, though the price between both those amps are pretty negligible ($70 for the PA2V2 and $60 for the E11). I like the E11 for the form factor since it'll basically be always attached to my iPod, but the PA2V2 seems a bit more popular and better reviewed. Also, it's nice to be able to charge the PA2V2 while it being in use, but I suppose it's not a critical knock against the E11 that it cannot do the same.
I had also briefly considered the E7 since it's also close in price with a DAC ($71), but I don't foresee ever using the DAC feature, so I guess it's not really a good choice for something that'll be used as a pure amp for most of its life. Does anyone have any recommendations for either of these for my car? I do plan on using it outside of my car, but probably not with headphones as I tend to use IEMs when walking out and about.
