kwkarth
Electronics guys... we have our plusses and minuses. With advent of digital everything, we're being phased out
- Sep 30, 2001
Yup, so far I can conclude that regardless of parallel, lion indeed running hotter than snow leopard. It doesn't take much for my fans to kick into 6k+ rpm. I hope they fix it soon.
Interesting.
I was observing the same temperature phenomena with my MacBook Air. I had reported a bug to Apple having to do with not being able to use two finger taps for right click.
I was directed to copy "/user/library/preferences" and set it aside, then essentially delete that actual folder "/user/library/preferences" The system created a fresh copy of the default condition .plist files and I then copied without replacing duplicates the set aside prefs files back into the original location. It not only seems to have fixed the two finger tap issue, but a host of other problems, one of which was the laptop running much hotter than it had been, crashing instability, etc.
