The Red Halo and LeJardin will give you a warmer thicker vocal.Yes, a fuller sound with more bass is exactly what I'm after along with a more realistic timbre and a warmer/thicker vocal. I was just wondering about the vocal placement but if you say more similar to the MKII then I would be a happy man as I love it too.
Many Thanks...
Oriolus Traillii Electrostatic Hybrid IEM discussion thread
- Thread starter tgx78
Amadeo Nospherathu
The mids, particularly the vocals, get a bit more attention as they have more body, warmth and weight. They are also much more natural and realistic. They are more accurate in conveying timbres and emotions.Yes, a fuller sound with more bass is exactly what I'm after along with a more realistic timbre and a warmer/thicker vocal. I was just wondering about the vocal placement but if you say more similar to the MKII then I would be a happy man as I love it too.
Many Thanks...
I already own Traillii. I was looking for something to alternate .... then a little faster, more detailed, with more panache and wickedness. So I don't know whether to try Jewel or go further and try Ragnar. Which from what I read should be more " analytical " than Jewel. The problem is, I don't know HOW MUCH more forward it is. I don't want it to be too much.Judging by the craziness going on right now, you could very well consider Traillii a good vintage mid-range IEM.
The people ran forward comparing the XE6, Noble and MM. For some, they will definitely be better, and someone like me will calmly stick with Traillii until the next big bang.
MaxwellDemon
- Oct 20, 2010
From my experience of trying both, I find that Jewel is a bit more forward and tighter than the Traillii while the Ragnar came off as being more analytical than the Traillii (but also a bit more dry too). I found the Jewel the "funnest" listen out of the three. Both have their advantages over the Traillii. Though I have to say, I didn't find either of those options created enough improvement for me to consider them. I might also be biased because I did only just joined the Traillii a month ago!
explain me better.... the differences between Jewel and Ragnar compared to Traillii. Could you help me (and not a little) to understand. Thanks for your availability.From my experience of trying both, I find that Jewel is a bit more forward and tighter than the Traillii while the Ragnar came off as being more analytical than the Traillii (but also a bit more dry too). I found the Jewel the "funnest" listen out of the three. Both have their advantages over the Traillii. Though I have to say, I didn't find either of those options created enough improvement for me to consider them. I might also be biased because I did only just joined the Traillii a month ago!
MaxwellDemon
- Oct 20, 2010
I'll try my best to answer though I am relying on a very short session of demo-ing on my end (around 30mins for both Ragnar and Jewel) and never owned either of those IEMs. The main differences that I got from demo-ing are the following:explain me better.... the differences between Jewel and Ragnar compared to Traillii. Could you help me (and not a little) to understand. Thanks for your availability.
Aroma Jewel vs Traillii:
- Punchier base, better texture, better clarity, this makes it the more engaging IEM out of the three -- can also feel "faster" because you can hear the beats
- Traillii has better mids from my short demo-ing, but it is only by an edge just because it seems more forward while mids are a bit more backward with the Jewel
Ragnar Viking vs Traillii:
- More sparkle, superb separation, layering, and soundstage, can easily pick up details and position of each component of the music -- perhaps the best at it out of the three. Maybe even what I consider to be the best at being a "referencing monitor"?
- Not a punchy bass, so it isn't a very "warm" IEM to listen to, Jewel is better at the bass than the Viking in memory and Ragnar is about the same bass level as Traillii
- Because of its impressive soundstage and separation, I felt like everything seems further away -- not necessarily a bad thing if you want to be able to hear all components of a music track, but if you are into the "musicality" factor, Ragnar might not be the best choice
Both Jewel and Vikings are, without a doubt, better than the Traillii. If you want an IEM that will do better bass AND better clarity... from Watercooler chat, it sounds like that IEM might be the UM's Multiverse Mentor. I have not heard of the MM to say for sure though.
Thanks for your answer. Traillii basses, I like them. I don't need more bass. I like Traillii's musicality, but overall I find it too relaxed. Surely Traillii doesn't get tired and it's really nice to hear but it lacks that aggressiveness and malice that would be needed in certain cases. Like metal or very technical and fast electronic music.I'll try my best to answer though I am relying on a very short session of demo-ing on my end (around 30mins for both Ragnar and Jewel) and never owned either of those IEMs. The main differences that I got from demo-ing are the following:
Oniemtilt
I’ll just add to the mix the Jomo GT 600. I own the Traillii, Jewel, Monarch MkII, MEXT, and a bunch of others I’m not remembering right now. I’m honestly not discerning enough to know forward, backward or sideways, but I am on a plane a couple times a week and grab one of my collection as I am leaving. I just spent several hours with the Jomo on (driven by an A&K SP 3k) and I really enjoyed it. I would guess a little v-shaped - punchy base and bright highs, but not fatiguing, very clear and detailed, and quite comfortable. If I recall it’s also a couple thousand less expensive than the Traillii. Could be worth a listen if you can get access to a pair. I’m not a shill for any brand - just an iem addict.
Thanks for the advice. I had read about Jomo gt 600 some time ago but after that he seemed to have disappeared almost everywhere. Maybe he didn't get the right match.I’ll just add to the mix the Jomo GT 600. I own the Traillii, Jewel, Monarch MkII, MEXT, and a bunch of others I’m not remembering right now. I’m honestly not discerning enough to know forward, backward or sideways, but I am on a plane a couple times a week and grab one of my collection as I am leaving. I just spent several hours with the Jomo on (driven by an A&K SP 3k) and I really enjoyed it. I would guess a little v-shaped - punchy base and bright highs, but not fatiguing, very clear and detailed, and quite comfortable. If I recall it’s also a couple thousand less expensive than the Traillii. Could be worth a listen if you can get access to a pair. I’m not a shill for any brand - just an iem addict.
I was also waiting for feedback on Nostalgia Audio Camelot.....but it too doesn't seem to cause much fanfare. Even if constructively it fascinated me a lot.
Sounds like the Traillii is big step up compared to either of the Mest. I love jazz and vocals so think this would be a good upgrade path.I did, but awhile ago. I felt it did not compare to the Traillii overall. I vaguely remember liking the bass of the Traillii better and preferring the Trailli’s midrange as well. I also think I like the Mk2 vs the OG. I was using rock, jazz and vocals to compare
I actually looked into the Red Halo but think it might be a bit thicker in the vocals than I want. I heard a while back that the Red Halo may have a bit less bass compared to the Traillii?The Red Halo and LeJardin will give you a warmer thicker vocal.
Sounds exactly what I'm after regarding the vocals body/warmth and a more realistic and natural timbre.The mids, particularly the vocals, get a bit more attention as they have more body, warmth and weight. They are also much more natural and realistic. They are more accurate in conveying timbres and emotions.
I am interested in the Jewel but Think I will head down the Traillii path first. I had the Monarch MKII and liked it but sold it to build up a bit of money to go higher up the IEM ladder.I’ll just add to the mix the Jomo GT 600. I own the Traillii, Jewel, Monarch MkII, MEXT, and a bunch of others I’m not remembering right now. I’m honestly not discerning enough to know forward, backward or sideways, but I am on a plane a couple times a week and grab one of my collection as I am leaving. I just spent several hours with the Jomo on (driven by an A&K SP 3k) and I really enjoyed it. I would guess a little v-shaped - punchy base and bright highs, but not fatiguing, very clear and detailed, and quite comfortable. If I recall it’s also a couple thousand less expensive than the Traillii. Could be worth a listen if you can get access to a pair. I’m not a shill for any brand - just an iem addict.
Thank you all your great help, I genuinely appreciate it
Based on what you describe and the music you like I think the Traillii is for you. It has some of the best ( if not the best ) mids in IEMs.Sounds like the Traillii is big step up compared to either of the Mest. I love jazz and vocals so think this would be a good upgrade path.
Yes, I definitely think it's what I'm looking especially the midsBased on what you describe and the music you like I think the Traillii is for you. It has some of the best ( if not the best ) mids in IEMs.
Amadeo Nospherathu
I am sure that here you have to compare everything yourself. What is too much for someone may not be enough for you. And vice versa.I already own Traillii. I was looking for something to alternate .... then a little faster, more detailed, with more panache and wickedness. So I don't know whether to try Jewel or go further and try Ragnar. Which from what I read should be more " analytical " than Jewel. The problem is, I don't know HOW MUCH more forward it is. I don't want it to be too much.
jlbrach
- Jun 4, 2005
the UM mason FS is a good choice...real good
