^ How are you guys even able to get 24/192 files onto you iDevice?
I didn't think an iDevice would even let you upload anything above 16/48.
Although I guess it is pointless if it is downconverted to 44.1 anyway?
I tried researching this previously, and there is so much misinformation out there I couldn't find what was or wasn't true.
Others have already posted regarding the use of 3rd party music player apps (in my case Onkyo HF Player or CanOpener) and the somewhat clunky file management system within iTunes used to add the hi-rez tracks (they are actually called "documents" but no matter) to those apps, but I've also seen references elsewhere as to how people have added those tracks directly to the stock Music player app. This is for PCM files only, not DSD.
I have never been successful in getting this to work, so I'm wondering if anyone else has, or if this functionality has perhaps since been defeated by Apple, via a software or iDevice firmware update.
The description of the process was something like this:
1)
DO NOT first add the hi-rez track or album to your iTunes library, store it in a separate folder, you will not use the iTunes sync button for the transfer.
2) Track must be in either ALAC or AIFF file format.
3) Either copy/paste or drag the hi-rez tracks from the separate folder directly to the icon for the connected iPod/Phone/Pad.
I use iTunes 10 on a Mac running OS10.8 Mountain Lion, and can't make this happen, but others swear it works. Anyone able to try it on a Windows machine?
Again, the key is supposedly not first having imported these hi-rez tracks into the iTunes library, that apparently ruins the process. I also don't know for sure if this is limited to 24/96 for instance, or if 24/192 will work. I can't get it to go at all.
