I have a FIIO Mont blank which I use for a portable solution, so I'm looking for a desktop solution to be honest.
Well you cant go wrong with some Schiit gear. Check out some of there products like the Magni, Modi or Valhalla to name a few.
I just wanted to give everyone a heads up.... I just traded for a Woo WA7 on the forums and the PM-3 pair very well with it. This is an outstanding little amp/DAC combo. I like it a little better with my Yulong DA8 II connected compared to the WA7 DAC, but only by a small margin.
Just my 2 cents.![]()
Found the LYR 2 at £400 but not sure How i'd plug it in to my d2x.
The WA7 is very good but how much did you get them for as this guys budget was way under that.
See I thought that but someone said the d2x was a good dac and i just needed a good amp. I originally asked the question ASUS ESSENCE ONE MUSES or Creative X7 then I was told to get a good amp instead.
Almost an entire month later, my parts for my SE cable finally arrive from Lunashops.com
It's an 8 wire Silver & Copper cable with 3 pole connectors.
They fit the headphone fine. I just have to remember only order from Lunashops if I don't really need the product.
All in all, not a bad cable for $24.
