disastermouse
The headband is hard plastic instead of protein leather? Sounds like a defective product.
Or a counterfeit. My Blue ones have a pleather cushioned headband.
Welcome to the wonderful world of PM-3 that is SE or balanced, depending you've got the right cable or not
It sounds fantastic with this cable and DP-X1 DAP. Not sure if Mojo fantastic yet, need to do some testing, but so far loving it.
The balanced portion of that cable (DAP side) is TRRS 2.5mm correct? I was on the Double Helix site looking at parts for a DIY cable, for my impending DP-X1 purchase.
Yes, it is 2.5mm at the DAP.
Sweet! I think I'm going to order up the parts in the next day or so to build my balanced cable.
So long as you have a soldering iron and the ability to solder, its def cheaper to make them yourself. Each end (even high end ones) will cost you 11 or 12$ and the cable is about 2 dollars a foot (4 x 4 = 16 feet of cable needed for a 4 foot cable).. Add those together and you come out with a cable costing you ~60 to make rather than 120$ to buy.
IMHO you can start off with something much cheaper and simpler like Mogami W2893 cable at ~.82 cents a foot (its a quad cable already so you only need one) and much cheaper adapters..You can even pretty it up relatively cheap with Techflex...
lol yeah years ago I used to recabled all my headphones with Mogami cables before I re-sold them.. As it was cheap and made the headphones usually stand out (AKA sale faster).
That link I gave you in the post was by the foot...
Solder station, solder flux ,helping hands, wire cutters, needle nose pliers and solder sucker would be a good start...
most everything you need to start can be found at Redco Audio
