gr8soundz
- Jun 28, 2014
True. I was thinking more along the lines of the extra ground (along with the extra power) like when using both headphone outs on the Ponoplayer.
But there is no extra ground connection, it's Left+/Left- on one output jack of the Pono Player, Right+/Right- on the other. That's differential signaling, and that's why XLR jacks have 2 active connections on a 3-pin one, 2x2 for a 4-pin.
Interesting article
http://www.hifiplus.com/articles/igor-levitsky-of-oppo-digital-discusses-headphone-technology/?utm_campaign=Hi-Fi%2B+Weekly+Emails&utm_medium=email&utm_source=email-392
Are you saying there is no additional, physical grounding on a balanced connection including one that uses two separate 3.5mm TRS jacks?
I don't think adding more power helps the PM-3 at all. I can't think of any reason why having double the voltage swing would be beneficial if an amp already provides sufficient power output.
To reach 105 dB SPL, the PM-3 would need 2.712 mW of power at 28 Ω, or 0.276 Vrms and 9.841 mA based on Innerfidelity's data. That's a trivial amount of power needed for most amplifiers and even a smartphone can output that. Why would having twice the available voltage swing be beneficial? If anything, it would make the volume management worse because you would have to lower it if the same gain is used, and that could potentially reach the channel imbalance region.
What would be much more likely of the difference in sound is the balanced-line architecture of the amp, which allows for common-mode noise rejection.
These are my favorite portable headphones which I use for work. I only wish my ears wouldn't get so warm with the pads but I appreciate the isolation the deal gives. I'd love to see an optional velour pad but I'm not sure that'll happen.
If they continue to sell I wouldn't be surprised to see more accessories become available. I'd like a case that can hold the ha-2 and pm-3s.
I have no idea of any actual sales figures for the PM-3's, but i would be willing to bet that they are already the best selling headphones Oppo has released. I agree with your supposition and if they continue to sell as well as they appear to be, you may begin seeing aftermarket accessories, other than cables, from third party manufacturers although i haven't a clue what those accessories may be.
I would love to see an aftermarket open up but when talking to the representative, he mentioned that the earpads are on very tight to create a good deal for isolation. He also said that they are very difficult to remove. It worries me that replacing the pads myself with an aftermarket pad would be too difficult or that I would mess something up. I wish zippo themselves would offer it and maybe I could send mine back for the change.
