Hi,
I chose the Apex MJ-16 mico-ATX case. It is about 5.25" wide, 13" high, and 15.75" deep. It is pretty cheap, about $50. It isn't too bad for the price, and comes with a crappy ATX SFX PSU. I was tempted to use it, but I might throw it in an old comp to revive it.
Yeah, it is a pretty huge cap (not as big as my hybrid 50F cap I have hooked up the Audison amplifier.) In order to connect these caps, they have to be charged before switching on the PC PSU. If I don't charge the cap to close to 12 V, then every ATX PSU I have tried will go into over-current protection or under-voltage protection- I am not sure which.
When I had my stereo amp as well as my class-D mono subwoofer 400W amp connected to a car sub in a sealed enclosure, the bass hits would often cause the PSU to go into protection. Adding the cap greatly reduced that problem. It was a PITA, because every time it happened, I would have to power off the PSU, discharge the cap, wait for the protection to go off, charge the cap, and power on the PSU again.
I solved the issue in general by just getting the Corsair HX1000W PSU, which is nearly identical to the Thermaltake Toughpower 1500W PSU. I think the only reason its rated 1000W is to maintain its 80 plus certification. It has respectable AC ripple measurements (about 25mV on the 12V rails.) It is actually two power supplies in one, and I just combined the rails by soldering all the leads on the modular power cables together onto 4 AWG power cable.
I think I will swap the 50F hybrid cap for the 1F electrolytic cap for the amp and just go ahead and get a 10uF Solen MKP for the PSU like you suggested. I'm very illiterate when it comes to small caps, so I wouldn't know which ones to get. Speaking of caps, check out this link to the modded SE90-PCI, I'm impressed.
Jimmy’s Junkyard » Blog Archive » Onkyo SE-90PCI Mod (Finally, It’s Done!)
I am tempted by a Sigma 11, but I don't have the skill level or patience at this point to get a kit. I just want an easy, cheap, and quality PSU. That is why I'm debating a Power-One linear supply for about $150.00.
I am amazed that a computer power supply (the Enermax Liberty Eco 400W) reviewed from a reputable site like Anandtech show measurements of 6.5mv on one of the 12V rails. I will probably pick this up, and I can't fathom getting a better SMPS for the money (I've been known to be wrong.)
-noob
