tbq22
- Dec 26, 2016
I have. I set the whole playlist on shuffle pretty frequently. No issues at all.
Excellent. Thanks so much -- you've pushed me from "maybe" to "definitely buying."
The Onkyo software is much more robust than any of the FiiO android software...Many thanks. Just to confirm: have you played that 17k track playist on the device? Because my x5 would happily accept large playlists, it would just freeze if I ever attempted to use it.
I have both the DP-X1 and Fiio X5iii and the DP-X1 is exponentially better in all aspects. My Dp-x1 has never given me the urge to take a sledge hammer to it like the FiiO does on a regular basis.The Onkyo software is much more robust than any of the FiiO android software...
I have an X7 too. I use the Onkyo
Question:
Has anyone connected this to a Schiit Modi through the USB output?
I'm trying to do that but it isn't working. I have a USB OTG cable that has male micro USB on one side for the DP-X1A and male USB B on the other side for the Modi. It seems like this should work, but the DP-X1A never sees the Modi.
If anyone has successfully done this, can you tell me what cable or cable combo you used?
Thanks!
The Angies are $899 and the Rosies are $699. If you want to go cheap the Havi B2 Pro's are less then$80 and sound very balanced with the DP-X1. Also you can get the PM3's direct from Oppo for $399.I get that this is an audiophile forum but the way you causally toss the "grab" some $2000 headphones makes me wonder about your motives. There are certainly viable options starting at close to 100% cheaper.
I need some advise
I purchased used DP-DX1. It was in very good condition. I noted some slowness and connectivity issues with wifi but that I can forget.
When I connect HPs via 3.5mm I only hear one side and where I get it working still for slight movement of the cable give the same issue.
I have read that there is a manufacturing defect in the 3.5mm and 2.5mm connector in DP-X1 and and they corrected this in DP-DX1A
I cannot return the unit and I am not sure Onkyo with assist in anyway. Any suggestions
Thanks
Sanjeewa
Thanks for the suggestion. I will try to contact themSorry to hear that. However, why do you think Onkyo will not assist you in getting this repaired? Onkyo has acknowledged this issue with the early DP-X1 models. The question is how much is it going to cost you. Have you tried going to the official Onkyo support form and posting this issue?
http://forums.onkyousa.com/viewforum.php?f=9&sid=850a5d17ec9e1c54092ff971adefc7df
Wondering if the problem with it upsampling 44.1 FLAC to 48 due to Android? is this still the case, and if so, have they indicated if it shall ever be resolved?
Is the DSD native also?
Picked up a DP-S1 due to the recent price discounting and it's my go-to pocket DAP now, still burning in but loving the sound already. Being non-Android it doesn't have the upsampling issue. I'm thinking of the larger DAP for a separate purpose and leaning towards the DP-X1 but I'm concerned as I'd rather not have the upsampling/resampling occur.
Thanks
-fm
Hi, I have a question I would like to know where you downloaded the usb drivers if you could pass the link
Hello the problem is that my player is dead does not turn on. And I did download its battery but now when I connect it to my laptop (windows 7 ultimate) it starts to load. That is why I want the drivers so that windows at least detect it and thus be able to restore with a stock rom.Which type of PC / OS are you using?
Are you looking for the ADB USB driver, so that you can root the DP-X1?
