dizzyraider
- May 26, 2010
Need help here with the Pioneer 300R.
How to allow some other applications (Tidal) to access an external usb device (external DAC/Amp) to stream music through it? By default it gives it Music app only.
Does not help.
It is possible to disable Music but I don't know what would happen...it offers to replace it with the factory version, What's that?
The way USB works with the Onkyo is when you plug an external USB DAC, the Onkyo Music App will ask you (the pop-up that you mentioned) for usage. This will give the Music app EXCLUSIVE use of the USB DAC, it will need to as the Music app uses Onkyo's on driver. This means that through the Music app, the music will not be up-sampled unless you tell it to. While the Music app has been granted exclusive use, all other apps cannot work.
If you select cancel, everything will work but will all be up-sampled to 192khz as it's done by Android.
BTW don't worry about the no clicking the right option in the pop up, it will show up again after you unplug and replug it into the DP-X1, even if you check use as default.
To make all over apps work with external USB, either select cancel when the pop up come up (and everything will be up-sampled to 192khz, you cannot change this) or
Sometimes USB won't detect properly if the screen is off, so if it's not connecting properly, turn on the screen then connect.
