- Oct 14, 2013
As noted, this is 2.5mm TRRS female to 3.5mm TRS male adapter. This specific adapter doesn't let you connect a SE cable (terminated in 3.5mm TRS) to a 2.5mm TRRS source. You would need a 3.5mm TRS to 2.5mm TRRS adapter to do this (this adapter does the opposite). And while you CAN make such an adapter, it's a really bad idea, and it would likely cause you to break your device. You really should not be plugging in a single ended cable with a shared common ground into a balanced source.
This adapter is designed to let you use your balanced cables with a single-ended device, rather that for letting you use single-ended cables on a balanced device. Just thought I'd clarify my statement a little bit. Such an adapter CAN be made, but it probably shouldn't be, and this adapter doesn't do it.
Agreed about it for every points. That is why having a balanced headphones is always better than having SE headphones ! My bad I didn't really look at what he was referring to
