froes
- Mar 30, 2010
I'd like to know this too.
I found it musashino LABEL CP-OCMX1C1/BR RED Fullarmor Case & Glass Protector for DP-CMX1
I’m connecting my CMX1 to Hugo2. Anyone know what is the best setting in CMX1? Should I set the output to PCM, DoP or Direct Transfer? Also should I upscaling all my music into 2.8/5.6Mhz DSD? All I want is to let my Hugo2 process my dsd file instead of cmx1 itself.
Hi could anybody tell me if it is possible to connect my Granbeat DP-CMX1 to a 2011 Macbook Pro that has the 3.5 earphones output and listen to Hi-Res Masters tracks through the Tidal desktop app? If yes what settings would I need on the Granbeat and if not do you have any suggestions?
Pity since it has a dac incorporated so I thought it could have been possible, anyway thanks for the feedback.Cmx1 cannot function as dac
The above is not possible
Was that an OTA update? What Android version do you have now?
btw, been watching Netflix with these
I guess i'm getting more benefits with the dual dac
I am waiting for mine. Maybe I'm wrong but I would swear this is what I need. A good DAC with just regular smartphone capability. I had a LG V20 and I sold it because of their size...6.0.1. Good sound. 90% DAP. 10% phone. I just expected a bit more interest from onkyo.
Phone is fine. I use it for calls. No problem. The current android version can't do all data via Bluetooth. But Bluetooth sound is ok. However not with an older android version. Somehow the edge on the top between phone and screen is not a perfect fit and so I have a long sharp edge.. well. Soundwise it is a great dap. All dap software details I can't comment on. The phone part is standard. I had 7 inch leagoo android phone for around 100$. It's screen is much better than DP-CMX1. Onkyo. Where are you?I am waiting for mine. Maybe I'm wrong but I would swear this is what I need. A good DAC with just regular smartphone capability. I had a LG V20 and I sold it because of their size...
P.S.: I guess this is the latest firmware update, January 2018 so I guess they are taking a little care...
http://www.hk.onkyo.com/en/support/searchresult?code=GRANBEAT DP-CMX1&tab=gj
Screen really that bad? That will be like pushing my fingers into my eyes (Slipknot dixit)...Phone is fine. I use it for calls. No problem. The current android version can't do all data via Bluetooth. But Bluetooth sound is ok. However not with an older android version. Somehow the edge on the top between phone and screen is not a perfect fit and so I have a long sharp edge.. well. Soundwise it is a great dap. All dap software details I can't comment on. The phone part is standard. I had 7 inch leagoo android phone for around 100$. It's screen is much better than DP-CMX1. Onkyo. Where are you?
