ONIX Alpha XI1 - Smallest & Most Affordable ONIX DAC - High-Power Portable USB DAC/AMP
Jul 31, 2024 at 3:58 AM Post #841 of 1,675
For my ears, paired with HD650, even my old ibasso D14 bushmaster sound better from onix, D14 soundstage is wider and bigger, more 3d sound, treble, and sound separation also better, onix is better with bass, smoothness, and warmer.
I just sold my onix last night.
Jul 31, 2024 at 5:00 AM Post #842 of 1,675
Your d14 is more than 2x the price of the Onix and you probably have unrealistic expectations. Nevertheless it's your ears and your money😁
Jul 31, 2024 at 7:41 AM Post #843 of 1,675
You do realize you now have to break out the Hugo...
I don't think it will compete... but would be curious as to how close it can come.
Would be interesting if you could take the output and feed into either RCA or even XLR inputs of an amp. ( Maybe it would require the USB-C splitter ... )
I am going to try the Hugo2. Last night was getting too late to start and my mind was getting tired. Hugo2 needs a longer warm up time. I listen to it from the RCA using a PWAudio adapter. One of the insanely priced Anniversary ones to give an unbalanced 4.4mm Pentacon connection. That alone is an advantage over the Mojo that needs a $300 bespoke Lectrik-S silver 8 wire ZMF adapter for the 4.4mm Pentacon cable of my 64 Audio Forte Blanc and Noble Ragnar. IMG_9106.jpeg
First time I looked at I think an Orpheus version 🤯
Jul 31, 2024 at 10:50 AM Post #844 of 1,675
After turning on the Hugo2 and setting it to play on its own for about 45 minutes through a set of Noble Ragnars. I came back from breakfast and did a quick A/B with the ONIX Alpha with one 3 minute Halie Loren song. Well, the tonality and timbre for at least this lounge jazz music is impressively close. The ONIX Alpha is a little shy on the plucky leading edge of the string double bass or the snap on the brush strokes on the snare drums, but otherwise if I just walked into my office and started hearing the Alpha, I might easily be fooled into thinking this was the Hugo2. The Mojo and Alpha are easy to tell appart because I think the Mojo is slightly not tonally accurate, maybe due to the number of adapters I have to go through to connect 4.4mm to 3.5mm. The Hugo2 with the PWAudio 1960s connector theoretically has a cleaner access to the Hugo2 amp.
This is pretty interesting. I would have thought that the Alpha was NOT going to be close. The Ragnars are pretty easy to drive, I think my Sony IER Z1R are more of a challenge for the Alpha. With the Sony, I definitely preferred the Kann Cube to the ONIX Alpha. With the Ragnar, the texture is only slightly less initial attack on the notes or sounds. The HUGO2 completely beats the Alpha in the sense of openness. Its like the sense of having a car moon roof (Onix) with all windows open and then going to a convertable car (Hugo2). By this time, I have heard my 5th song on the album.
I'll go looking around for a shorter USB cable and switch USB ports, maybe I can get a little bit more voltage from one of the other combinations. Technology has definitely advanced quite a bit since the Hugo2 was launched.
A hundred dollars...$109... !
Jul 31, 2024 at 11:02 AM Post #845 of 1,675
I'll spend some time with DSD 256... Alpha challenging a desktop dac/amp...humm, I've only tried easy to drive loads and well for those it's not doing a bad job.
Jul 31, 2024 at 8:13 PM Post #846 of 1,675
Well, I'm not able to tell if I have one of the defective firmware versions. Since I can't seem to get it to play DSD or DSD over DoP, I probably have
one of the early ones that just won't sync up with DSD files.
I've tried to understand the manual, but I have no idea how to get it to display the firmware or to get USB 1.0 to show up. It always shows USB 2.0 and won't show me the menu options to display the firmware version number.
Tried many things to try to get DSD files to play including down sampling and memory conversion remapping of the format. It just doesn't like DSD.
I looked at the ONIX website, I see no support for upgrading the firmware. Well, if this is not my lack of understanding then DSD is not well supported.
Update: I still can't get JRiver MC 32 to play DSD with the Alpha, but I am able to get an older version 1.6of FooBar2000 to play DSD.
Emilie-Claire Barlow "Live in Tokyo" DSD64
Jul 31, 2024 at 8:53 PM Post #847 of 1,675
Here's a clearer how-to: https://www.head-fi.org/threads/oni...wer-portable-usb-dac-amp.973027/post-18213165
You can connect your Alpha to some other phone than an iPhone, or a PC. It'd work too.
Have you tried DSD playback through something like UAPP or Hiby Music on an Android phone with the Alpha connected and used in exclusive mode? Would be useful to help narrow down the issue. It could just be a one-off with your JRiver.
Jul 31, 2024 at 9:02 PM Post #848 of 1,675
DSD is fully supported on XI1.
For use with smartphones, it should work smoothly once you have DSD set to native and app is accessing XI1 in exclusive mode.
For Windows, make sure you have XI1 drivers installed (available on ONIX Website). If DSD works with fine your Foobar, it seems there might be some setting in JRiver that's causing the issue.
For Foobar, here is guide, including needed components: https://drive.google.com/file/d/1c1JEwItAkk4ISPRR3bp--7nqxy93tDtd/view?usp=drive_link
To get to menu, you simply hold down the Play/Pause button for 2 seconds.
If this one doesn't work at all, you might have unit from the very first run and we would recommend contacting your Chinese seller for replacement unit.
Jul 31, 2024 at 9:47 PM Post #849 of 1,675
Thank you,
Well, I followed the directions and the 9th item on the menu was the IDLE TIME menu item so I assume this means I have a different version than 1.0.3.
@Shanling Can the serial number tell us what version I have? Mine starts 3030... and ends in ...3464
I also suspect this is more of a problem with JRiver since I am able to get DSD256 to play with FooBar2000. And it sounds fantastic on FooBar2000 1.6
Jul 31, 2024 at 10:27 PM Post #850 of 1,675
I've got the Hugo2 nice and hot after playing some DSD through it.
Now going back and forth with some Alba Molina "El Beso", Spanish singer and classical acoustical guitarist.
You can clearly hear if she is using her knuckles on the guitar or the palm of her hand to thump the guitar and where.
Yes, the Hugo2 is slightly fuller at the lower ranges of her husky voice. Piano is a hint more detailed and well rounded notes compared to the ONIX.
As mentioned, there is a bit more atmosphere and openness to the sound stage. Hugo2 is obviously more powerful presentation, almost agressive in comparison.
But the sound is a lot closer and similar than different. I don't think my wife can tell the difference switching back and forth.
If I had just bought the Hugo2, I think I would be taking it back to the store right about now.
The difference is about as much difference as comparing Kimber Kable Select XLR copper / silver hybrid to Select XLR all silver interconnects. Yes there was a difference, but was it worth paying that much more for minute differences?
Jul 31, 2024 at 10:39 PM Post #851 of 1,675
Thank you,
You need to connect as UAC1.0 (hold down the play/pasue button when inserting cable). LED will be red and screen will show UAC1.0.
Jul 31, 2024 at 10:45 PM Post #852 of 1,675
And to think you may have a 'defective' unit. (I kid, I kid )
:ksc75smile:
(Actually I think the problem maybe elsewhere... but I'm the eternal optimist.)
Wow. Definitely punching up.
I'm not sure if you have the Hugo2 or the Hugo2TT but if its the Hugo2... that's ~25X the price of the Alpha XI1.
I guess for casual listening... (C'est Moi) vs An Analytical Audiophile, Its money well spent.
Currently my unit is on the plane flying to the US...
Jul 31, 2024 at 10:54 PM Post #853 of 1,675
:ksc75smile:
I'm comparing against the Hugo2 portable. I also have a HugoTT2 desktop with the Hugo M-Scaler with $4,000 Kimber Kable Select 1136 99.99% pure silver interconnects.
The only "big" difference for me with the ONIX and the Hugo2 portable is that the Hugo2 has the ability to disappear. You can forget it's a recording and instead experience the venue if the recording is good enough. ONIX is close, but occationally you sort of wake up from the illusion and realize it is still just a recording you are listing too.
Jul 31, 2024 at 10:59 PM Post #854 of 1,675
Old pictures, Here's the TT2/M-Scaler. What a beast.
Jul 31, 2024 at 11:06 PM Post #855 of 1,675
LOL... Even I, who is just an ordinary person and not an audiophile expert, can differentiate the Onix from the Ibasso D14 using HD650, and I can really feel the difference.
