So finally we've got somewhere: HD 800 and Elear have stronger upper-frequency impact than the TH900. I would have wondered if it was the other way around. So I wasn't wrong with my assumption that the HD 800 lacked bass impact to your ears – that's what I remember you mentioning earlier.
Yes, explosive sound is what I understand with impact. But not necessarily feeling it – this will only happen with closed headphones, or maybe with some open dynamic headphones at extreme bass levels. Maybe that's why the equalized TH900 has become your reference in terms of «impact»? Also, a bass-heavy headphone equalized for more bass as reference for impact? If you're a basshead, it's only logical that the HD 800 won't satisfy you in this respect.
I still don't understand what you missed with the HD 800, say compared with the SR-207, when it comes to bass impact. The electrostat can impossibly beat an equalized HD 800 there. And as to higher frequencies: Most likely transients will sound even faster on the SR-207... but more impactful!? I really doubt I would perceive the same. However, I take it you've made this comparison out of your memory, not by direct comparison. One thing is still worth mentioning: my pair of HD 800 has a damping modification, which contributes quite a bit to an improved transient response. But as far as I recall, the original HD 800 has an impressive quality of impact, also at low frequencies (when equalized), which are barely affected by the damping mod, BTW.
As I have stated more than once, the TH900 tends to be very soft with things like snare drums. Its bass impact is also pretty soft without EQ, even despite being boosted by a few decibels. And its entire texture is soft and smooth. I never said the equalized TH900 is my reference in terms of bass impact, and I never said it was my reference for anything at all either. Stop putting words in my mouth, please. All I said is that you can get stronger bass impact when you boost the bass.
http://www.head-fi.org/t/716711/the-hardest-hitting-headphones-are-the-extreme-bass-club
That thread is about which headphones have the most bass impact when you boost the bass to extreme levels with EQ. The JVC HA-SZ2000 is the top-ranked headphone there. I own it as well. You can make it sound like a car subwoofer, but the sound quality can't compare to audiophile headphones. Although the TH900 is ranked #2 there, I haven't even bothered equalizing it much, as I only recently got it.
Anyway...I keep saying over and over that upper frequency impact is more important to me than bass impact. So when I talk about impact, I am more often referring to things like snare drums rather than bass. When I talk about feeling the impact, I am also often talking about feeling the drums hit, which involves upper frequencies. Play that test track I linked to for an example.
The 207 had realistic
upper frequency impact,
every once in awhile. (Plenty of headphones can fit that description. I also never said that the HD 800 did not fit that description as well.) I did not say anything about its bass impact. I just said impact before, without specifying. Didn't realize you were going to continue making assumptions...
But actually, plenty of people say that, when paired with the right amp, the STAX SR-009 (and various other electrostats) has much stronger bass impact than the HD 800 and various other non-electrostats. You're making far too many assumptions here.
The problem I had with the bass (actually, the entire sound) of the HD 800 is that it's too tight and dry, regardless of EQ. (Even with extreme bass boosts.)
The stock tuning of a headphone is not relevant when you use EQ. You can increase the bass quantity of any headphone to any level you want, as long as your amp and the drivers can handle it.
