JaZZ
I don't doubt that the HD 800 would be improved with physical modifications and perhaps tube amps. My comments on it were only relating to the headphone in stock form, with and without equalization, and driven from solid state DAC/amps such as the 430HAD, HDVD 800, and Mojo. (I have mentioned in the past that its basic sound signature remained the same no matter how powerful the amp was.)
All I know is that when I listen to STAX, it sounds a lot like real instruments, and when I listen to the HD 800 (regardless of amplification or EQ), it sounds...well...like how I described it here. I acknowledge its abilities, but they come at too dear a cost. I've had my entire life to become familiar with the sound of real instruments, and the HD 800 just comes off as an alien robot to me. If the various tweaks available could make it stop sounding like that, and also have proper power/impact/aggression, that would impress me.
There's nothing wrong with your preference, and I can easily reproduce it, although in detail I don't hear the same flaws as you do. To me the HD 800 sounds ultra-fast and -impactful, at least when modified and equalized, has even a bit more punch than my two electrostats across the spectrum. I can see why you perceive the sound of your SR-207 as more natural – in certain sonic aspects I'm sure I would agree. However, in others it's the other way around.
It's seductive to think that one's own hearing be somehow better than that of others, particularly based on experience as a musician. But you're not alone in this position, I've been a (Rock/Jazz) musician myself – playing bass guitar and double bass –, and I'm sure there are many others with active musical experience. Moreover I attend classical concerts now and then, so I know the sound of acoustic instruments – my main reference since ever – quite well. As mentioned in the conversation between you and me, the HD 800 isn't even my number one – that's my (modified and equalized) HE1000 (V1). I'm not sure if you would agree with me, after all I think that it reproduces instrument timbres best of all headphones I own and know. Its planar magnetic drivers use an ultra-thin and -light foil membrane approaching electrostatics', and a special asymmetrical magnet system makes for extreme acoustic openness possibly enabling the least inner reflections of any buyable headphone to date (relatively speaking – in absolute terms it's still too much); as I hear it, this pays off in the most realistic sonic colors and an excellent imaging of spatial depth. The bad thing is that with its original tuning and with the stock cable it sounds a bit slow, but that changes a lot after recabling and equalizing, which increases resolution to quasi-electrostatic level. The «quasi» may even be a benefit, since it renounces the typical stator reflections responsible for the etherealism electrostats are known for.
So to each his and her own! Do you still have access to a pair of SR-207? I'm asking because I had the suspicion that your memory could have transfigured its sound quality to unrealistic levels – especially considering the entry-level amp you were using with it.
