Hi, JHutchins
does not allow Amazon Music to stream
---Do you mean that you can't download the files to X7 or fail to log in the Amazon Music? Are there any messages when you use that app?
Hi,
In v3.04 I can log in to Amazon Music and can download tracks to the internal SD card (not external). The downloaded tracks will then play in the Amazon Music app. If I try to stream a track from the Amazon server the track will select, play 1second and then lock up.
Of equal concern is the lack of Bluetooth connectivity I have in v3.04 which does not appear to be shared with other users. If the connection problem was confined to one device then I would suspect the receiving devices, however it seems to affect all the devices I try to connect with. Testing the same devices with my iPhone and iPad all connect correctly.
Just to repeat none of these issues are present in FW2.0
Many thanks for your concern and help.
