Angelch
- Aug 8, 2015
Hi Joe,
Whats new in this firmware 1.16 Beta ?
Hi Joe,
There is a small problem in firmware 1.16beta. When I turn on the player with the headphones inserted, and set to play music, the headphones hear unpleasant wheezing, instead of clicking relays. When I am turning off the player, then popping sound in the headphones, instead of clicking relays.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Hello wiser87,
What's the NB code of your X3? (System settings->About X3)
I upgraded to v1.16b and so far things work great. The removal of the 5800 song limit is a huge improvement that I was really waiting for. Thanks for implementing it!
A few improvements and fixes that I'd very much like to see include:
- Hebrew song/artist names are displayed incorrectly (characters are displayed as generic squares, probably because the font in use is missing Hebrew glyphs)
- Acceleration of the wheel is needed to makes going through long lists easier. Ideally, the faster the wheel is spun, the more acceleration should be applied.
- EQ should be accessible with a shortcut. Currently it requires a lot of clicks and wheel turns to get to.
- Gain mode should be remembered per each EQ mode. For example, my two most used headphones are Beyerdynamic DT990 Pro 250Ohm and Denon AH-D1100. With the DT990 I'm using High gain and a EQ with reduced treble, where as with the D1100 I'm using Low gain and EQ with increased treble. You can imagine how long it takes to set the player up when switching headphones. An EQ that remembers gain setting would make it much easier. It would also be cool to be able to rename each EQ mode. I would prefer to use the name of headphones for these modes. I think the Rock, Classic, Jazz names etc are not used by most users in the context of these genres.
- Switching from no-EQ to EQ results in reduced volume. I understand why this is so, but most other players employ volume matching which in practice is more useful. It would be nice to add this as an option.
- Seeing the SD card and OTG directory in the top level doesn't make sense if no OTG device is connected. It would be better to make the root of the SD card the top level folder if OTG is not in use.
Thanks again for continuing to support your products with frequent firmware upgrades. It's very much appreciated!
Goodyfresh, I'm not on the FiiO forums and would be more than happy if you quoted me there.
As for the DT990 and High gain, I'm sure I can squeeze out a bit more with an external amp, but carrying one is too cumbersome for my liking (speaking as someone who owns an E11). The sound of the X3II+DT990 combo is more than satisfactory by my modest standards, it's actually pleasurable![]()
