2015-06-08
Beta firmware version 1.11 for the X3 2nd gen is now available!
https://www.dropbox.com/s/4yb1k8gb3kvsbxf/X3%202nd%20gen%20FW1.11beta.zip?dl=0
After downloading the update, please unpack (unZIP) the package and read the update instructions contained within.
Please note that all firmware posted in this thread are beta firmware--please post in this dedicated thread if you have any issues with these versions, and if you encounter serious problems, consider flashing back to a stable release.
The following changes and improvements were made to FW1.11 compared to FW1.1:
1. Pressing the Back button from the Now Playing screen will now always take you to the folder / album / etc. from which the current song is selected. This is true even after navigating to the main menu or powering the X3 off and back on;
2. Added support for M3U playlists without the "#EXTM3U" header;
3. Equalizer may now also be used with line out and coaxial output;
4. Improved gapless playback of single music files split by CUE sheets;
5. Fixed issue where certain situations caused the player to play songs without sound;
6. Fixed issue where certain music files caused the player to hang;
7. The default function of the multifunction output has been changed to line out, to cater to the majority of users using it as line out;
8. Reduced crackling noises when inserting and removing earphones while music is playing;
9. Fixed issue where there would be no sound on playback if connections to the headphone out / line out were broken and reconnected / changed within one second;
10. Fixed issue where the X3 has trouble entering standby if a micro SD card or OTG storage was removed while music was playing;
11. Fixed issue where the headphone output made noises if the volume is changed using the volume keys when the player is acting as USB DAC;
12. "Idle poweroff" renamed "Idle standby" to correct description of the function.
Known issue: users with X3's of NB code W233b (check in System Settings->About X3) may receive an error message on disconnecting / reconnecting headphones after flashing to this firmware. Please flash back to 1.1 if you receive this error and inform us of the issue.
Looking forward to your feedback
