Official X3 2nd gen beta firmware thread--FW1.44: library search, ReplayGain, high speed USB, DoP, D2P...
Jun 8, 2015 at 12:09 PM Post #16 of 367
  I've always noticed this, also had it on the OG X3 too.
Strange,  I never noticed it until after this update.
As long as it is normal and it is not just me having it then I suppose it isn't anything to worry about
Jun 8, 2015 at 12:11 PM Post #17 of 367
To be clear, you hear clicking coming from the player, not the headphones, correct?
Jun 8, 2015 at 12:29 PM Post #19 of 367
Am I the only one with the 6 s lag from the menu button? – With the music paused it's 3-4 s.
Jun 8, 2015 at 12:53 PM Post #20 of 367
First time after the update rewind of an album with cue sheet did not work - it gave me an error that file is not supported.
After restart, it was fine.
+ Folder back from Play Now works and also seems to remember the cursor position
+ Gapless is fine now
+ Card is now called SD card rather than TF card
- Cracking noise still present, even more so, especially first time i take the earphones out there is a loud crack. Inserting them and putting back after that is still noisy but not as much as the first time
And I really wish you made the player to start on PAUSE after shut off and when Remember Position is engaged. Basically, I think it is best if pause is remebered when moving between tracks and is not canceled by other buttons.
Jun 8, 2015 at 1:00 PM Post #21 of 367
And how about the menu button?
Jun 8, 2015 at 1:00 PM Post #22 of 367
Yes, it did some weird things after update, like playing tracks and then saying file not recognized, but a media library update solved this issue.
Changing from DAC to LO and HO and vica versa often caused freezing before. Like the track was playing according to the screen, but there was no sound.
 This seem to be solved so far with the new firmware, which is a big +.
Jun 8, 2015 at 1:42 PM Post #25 of 367
For the moment I went back to firmware 1.1. No lag at all here, immediate reaction.
Jun 8, 2015 at 6:52 PM Post #29 of 367
Okay just installed new firmware and here comes the first [COLOR=FF0000]BUG!![/COLOR]
When I normally remove the earphone from the jack the error message appears as " [COLOR=FF0000]Output error! please reinsert earphones[/COLOR]" And player hangs. No other buttons work except volume keys and power button.
Need to restart it all over again.
Forgive for the bad picture.
You're the only person having this issue so far... can you go to System Settings->about X3 and tell me the NB number of your machine?
Thanks!
Jun 8, 2015 at 6:55 PM Post #30 of 367
Hi JaZZ,
Have you re-updated the media library? Also, how big is your music library?
--Joe
