Inear
- Nov 17, 2010
Anyone using these at the gym/biking?
How do you mean, maxing out the volyme control in headphone app?Try maxing out the volume control in ‘headphone” app. It seems to limit headroom when at anywhere less than max. That worked for me.
The facility of 'following' or not - is a Bluetooth setting on your phone - 'Media volume sync'. On Android phones at any rate.How do you mean, maxing out the volyme control in headphone app?
If I max vilyme in app, my iphone ”follows”
Im slow maybe, but dont follow
Hey,
Does any of you use these for phone calls? I had a pair but returned them due to the bad call quality. I really like them otherwise... I'm thinking of getting them another chance, maybe I got a Monday sample last time?
What do you guys think?
Hey,
Hey,
Ive never been a wireless anything guy.. (ESPECIALLY headphones...) but i decided to try the Sonys (WH-1000xm3s) earlier this year and ended up buying my wife a set the day mine arrived... If you travel a LOT and find it a pain to carry a DAC with you (You know who you are), i highly recommend these HPs..
They still arent "Hi-Fi" (although very very close!) grade headphones with a good mobile dac, however you are significantly cutting down on:
A. Complexity = 2 main buttons on headset + the touch interface which is nice and easy!+ Charge port (or can use backup wired input if they die), + Enable bluetooth button on your phone..
VS... DAC (Usb to source=2 ports, 1+ adapter, + another battery inside portable DAC that needs to be charged/monitored, interface to headphones=at least 1 port)
B. Price.. Portable DAC to get LDAC+Tidal quality is going to run at least another 200-500?$ + Accessories you require which sometimes can be very expensive. (Especially if you wanna Bluetooth your DAC if it doesn't have it..)
C. Time (for setup/travel).. If you travel this will mean the most to you which is why you would consider these in the first place.. You know between airport terminals you simply cant be dealing with wires going from a phone to a DAC to a headset and stay focused on your work/travel... Its just a pain in the rear.
I have always been a sennheiser fan (I like the 600/650 series) (My first pair of over ear headphones about 15?yrs ago were the Senn HD280s which i still use for certain things!)
Point is... Never would have bought "Sony" (Or Bose/Any other name like this) headphone before... These are by far a quality product and great for the Air Traveler who just needs to have something simple/noise blocking. This is the 1 time i want active cancellation...
i use it for phone calls and the quality is not good.Hey,
Tried once on a call and person couldn’t hear me well so never bothered again.Hey,
Might be a stupid question, but how do you keep the ear-tips clean? Just with water? I just got a pair because of all the positive reviews I’ve read, and because I really like the over-ears models. Not typical an in-ear guy, but I’ve decided to give these a chance.
Is there any where I can buy a spare set of the ear-tips? The official that comes in the box?
