- Oct 14, 2013
So, I have been burning it in while listening to it. However, I found it exciting to have found the correct DSP setting out of all of it features. You can have all 6 different filters from AKM4497EQ itself, and then DSD-Remastering engine together with DSD filtering options from Sony Proprietary Digital Signal Processor (DSP). Then there are DSEE HX AI, Vinyl engine, Bass/treble tone control....etc....but I found what I have been after now, and I will share it out here. Yes, sound is subjective and what I prefer may not be your cup of tea. I would love it if everybody could share their finding for their favorite genres
So, my genres of enjoyments are hugely varied from classical to instruments, orchestra, jazz, classic rock, classic pop, modern pop...etc...I have found a perfect match for the performances that doesn’t everything universally well, and hugely benefit from Tonal body, timbres density, liquidity and full of emotions. My main genres is still pop, instruments...
Setting > Output Setting > DAC filtering setting > Sharp
Setting > Device setting > Battery preferred
DSD playback setting > select filtering gain > Slow Roll Off
Back to setting > Sound > Direct Source > DSD Remastering
It is an issue common across all walkman OS, so it is certainly unique to DMP-Z1.In DAC mode, the DMP will lag if used with youtube/netflix right? Just wanna make sure it's not my unit's fault.
I notice there is no lag using Bluetooth connection, or at least the lag is much less noticeable compared to USB DAC mode.Got it. And I assume there's no way around it? I mean watching The Office through the DMP might be fun
You are right . It all comes down to the engineering and components being used. This was one of the reason why I went with the DMP. Just for one example, DSD256 remastered on TA-ZH1ES may not sound as good as DSD128 on the DMP for a fact that DMP analog and digital essential circuitry are all built with PML caps that minimizes or eliminate the acoustic noises due to piezoelectric, and while the Fine Sound resistors are the most precise resistors with highest tolerances and developed especially for Music and frequencies retentions by itself.Just my 2 cents but if the "wow" is there then all the numbers are meaningless? (except maybe the prices)
