Not exactly, but some of them could give you a good time over it
. I traveled with WM-1Z before, and most of the time, all went well.
One of the thing that Sony do not advertise or mention about the
unique-capability of the DMP-Z1.
The Artificial Intelligent inside the DMP-Z1.
The idea is that while listening to PCM, a raw
compressed (that is right, FLAC is still compressed) data of binary coding, we rely on the algorithms, and the way each different modulators are working to convert and reconstruct the sound into analog reproduction. That means, we
use the same set of algorithm, modulation for everything, genres, instruments...etc...etc..
The question is, can you cook geese the way you do Beef ? The answer is
NNNOOO!
So, in order to achieve a better and more accurate fidelity, you would have to be able to realize what genres is being played, what instruments you are having, Strings, drums, brass, winds, what type....etc.....and you apply different methods to reconstruct the end results. In order to do this, you need a good engineers, studio, and great set of ears to
remaster it.
But, how about, we have it inside your device on the go ?
Welcome to AI-DSEE-HX.
If I am sold by the DMP-Z1, this is the only reason
The only device in the world to take advantage of this . So you guys, who have this, and don’t use this function....I don’t know what to say, but I thought I should bring it up to you all
Remember, you can not cook Chicken the way you do Beef. Therefore, you can not use the same algorithms and modulation for the same of everything. Enjoy guys!
