gerelmx1986
CEW2 region sounds so clean with the bass as J, with the added bonus of more details (not so polite as J)
Did you fix your problem? Just curious. Mine is working fine. Bisher alles gut mit dem DMPYou certainly have a point, but let's not forget that while these $5K+ are very much a hard fact, the 5% aren't. They are just a) one man's opinion and b) a rough guesstimate at most that should not be taken literally. Basically, since we have no way of actually measuring these things (as they're not only subjective but also not quantifiable), they're basically just a way of saying, in my mind, it's pretty close, and nothing else. Personally, I try not to throw around numbers like that because they're too often taken as gospel, thus spawning a new narrative ("They say the DMP-Z1 is just 5 % better than the WM-1Z"), which is not really helpful, but perhaps they can help others to get a basic feel for at least a perceived difference of things.
That being said, I still don't really know what to make of my own DMP-Z1. At times, it totally wows me, and then again, it will leave me more or less cold. I haven't yet worked out all of the contributing variables. It certainly seems to have something to do with quality of the music files, but it does not seem limited to that. Will have to do more listening and determining; so far I have just a measly 24 hours on my unit, as work is plentiful and listening time more or less restricted to nights.
I do, however, have a problem. When the DMP-Z1 is plugged in, I hear a humming noise via the IER-Z1 that I don't perceive with the MDR-Z1. At first I thought it was just due to the IER-Z1R being more sensitive, but the strange thing is that the humming disappears as soon as I touch either the power cable, the IEM's cable or the unit itself. Is anyone else experiencing this? Could it be some sort of grounds related problem? If so, shouldn't it be perceivable on the MDR-Z1R as well? It only seems to be an issue when the power cable is plugged in. (Sorry, I'm a total tech dyslexic, if that was not apparent.) Strangely, I'm almost sure that I didn't hear it in the first couple of hours, despite the unit loading while I listened. I remember being excited about the deeply black background, and now this is ruining the experience a bit. It's not really audible while music is playing, but quite apparent during very quiet passages or between songs, and to be honest, it annoys me quite a bit. Anyone have an idea what could be happening? TIA!
Id it both, SW and HW thing. The AKM33””4497 supports max 245As more DSD music are now available in higher resolution, 512 or even 1024fs, I’ve recently bought some 512fs tracks, which don’t play on the DMP-Z1, yet my other 'lower' DAPs can handle. Probably a dumb question but is decoding higher DSD files a software or hardware thing? If the former, could it be enabled through firmware upgrade?
Where do you rent gear?Really? I think i have to rent the DMP-Z1 one more time. I never tested changing the Region Code
because it doesn't have the limiter, i haven't thought about it. I only used it with CEW2 but i use all my other Sony Gear with J
I changed the Region Code on my WM1Z (it was an EU Model) and the region code of the WM1A (it was a Japanese Model. changed it to CEW2 so i could change it to german and than back to J to remove the limiter) but it never changed the sound on those two.
I would never have expected that it would have any influence on the DMP-Z1, but now im curious to find out
Sony Gear? At the Sony Store.Where do you rent gear?
Would you be so kind and provide the link to that store? Thanks!Sony Gear? At the Sony Store.
Uhm? To the Sony store? SureWould you be so kind and provide the link to that store? Thanks!
Thanks for the info! Back in 2016 Sony phased out all of their remaining 10 retail stores in the US. Quite unfortunate! Not only are you lucky to have Sony retail store(s) in Germany but also you are able to rent equipment from them, which is the services I do not recall to have been ever offered in the States.Uhm? To the Sony store? Sure
https://www.sony.de/sonystoreberlin
But it wouldn't had been that hard to find that yourself^^ not that I mind posting that link, just wondering. It's not like a hidden secret place of something, it's the official Sony Store from Sony.
But you have to pay at least a deposit via Credit Card and be registered as an customer there. I think there are no other fees, just that you know.
Wow! That is sad to hear, and i thought germany was doing bad in terms of Sony. We only have one single store and its shrinking in size every year. I don't know how long it will stay here.Thanks for the info! Back in 2016 Sony phased out all of their remaining 10 retail stores in the US. Quite unfortunate! Not only are you lucky to have Sony retail store(s) in Germany but also you are able to rent equipment from them, which is the services I do not recall to have been ever offered in the States.
10 hours a day... this is like serious business / like having a full-time job :-D307 hours in the last month
