That's strange .. with my Dell Win 10pro laptop ... I use a Sony WM1A as USB-C dac and also watch TV or Films without any issue (even in Bluetooth) it' correctly synced.
The stock DMP-Z1 firmware has received a fix, that will allow it show all album cover images.
If you're not familiar with the issue, the firmware will only display baseline JPEG images, or non interlaced PNG ones as album covers. With this fix, all types of JPEG and PNG images will now be shown.
You can download this modified stock fimware here: CLICK
Enjoy!
Note: Before aNyOnE will say "But wait MrWalkman, you said you cannot mod firmwares without owning the device.", this fix doesn't need experimenting/testing, and it's risk free. Thanks for your understanding.
can you tell me how to installed your modified firmware via mac? I downloaded your firmwared via the link you provided and there are two versions of the firmware. I unzipped the file but there is no "update tool" only the .exe file and my macbook pro cannot open or do anything with it. Does your firmware only works on windows?
Frankly, I don't remember if one was included. The manual usually lists what is in the box, but I don't recall if one was included. And I put the box in storage, so I can't check. Sorry.
Thanks. I have a feeling I’d read somewhere that someone had said it wasn’t included. Is any USB - C cable suitable ? I obviously can’t transfer onto internal storage without one.
