Pokemonn
You guys should know that IF Sony start to sell "perfect" products, then many small company will bankrupt...Lol
One of my friend who has the t+a dsd8 dac and uses its home PC to upsample everything to DSD using HQplayer said it best. He told me it isn't small enough to be portable and if you are at home why would you not just spend that money on a DAC/amp setup that can eventually be used in your home stereo if you happened to want to go down that path.Thanks! I think in all of the newest release, the IER-Z1R is more a unique Sony move. It has all the fancy stuff one can dream off. The DMP-Z1 is such a failure for it pricing. I don’t see this unit to be competing against a proper desktop setup at the same price at all.
The power output is only 1.5W at 16Ohms. Now...that is a bit sad. Why couldn’t Sony do with Sony own discrete amps....
Buy by 1000x and the price of
TPA6120A2: 1.66 cents
I've heard the best potentiometer is none! But I do believe the RK50 will impact the sound, however lack of discrete headphone amp is very disappointing. It feels like they were giving a target selling point and were told to make a product as soon as possible!DMP-Z1 is said to be carriable ! It is the first of it kind, you just carry it inside your backpack if needed, and onto airplane pack to listen to it
Still, this price point, and the pricing between rk50 vs tpa is mind boggling
Very much agreed here. It sounds like they ran out of space and decided to use the integrated amp module to save space. If you notice, Sony didn't say much about the amp module except "high quality analog amp module". We need extreme top end at this level.Even Burson, a small company, can do a discrete Op-Amp design. I don’t see why Sony can not....the idea of expensive front end including RK50 to just be choked down by TPA is crazy and make no senses. Even IER-Z1R has discrete components for Cross over (thin film Capacitors and F-Resistors)
