soozieq
- Jul 17, 2007
Isolation is really good. I haven't used them on the train yet, but I was pointing out that as the leakage is so slight (when tested in a quiet room) - other people on a train/plane/bus wouldn't be able to hear anything 'leaking' from the headphones. I am waiting for UO to come home (unsignificant other
) and I'll get him to check the leakage of the CX300s compared with the 700s. He said he could barely hear anything coming from the 700s and I had them pretty loud for 'testing' purposes, so I'll do the same thing later with the 300s and let you know.
I can wear them over my ears if I want and they still stay put. But as the cable is no longer a problem when it hangs down, I prefer to wear them straight down. The cable just stays put. As for microphonics/cord noise, there's nothing! I don't know if it's because of how the cable is constructed or whatever, but there's zilch noise/microphonics at all.
No and no. Definitely not harsh at all. Sibilant only on certain songs and I think that's something to do with the singer standing too close to the microphone (someone say if I'm wrong?), but I've had several pairs of headphones including the E500, and the same songs produce the same sibilance, so I have to assume it's the singer/microphone thing.
The only concern I can see, is that the filters could get clogged quite easily and I can't see how to clean them. One of the reviewers said he used to stick a pin in his Sony filters when they got clogged, but he didn't really want to do that with an expensive set of headphones. For the moment I'm making sure not to throw them anywhere dusty
until I figure out how to clean the nozzles.
Re: pics. I'll try, but I still haven't managed to upload a photo on here yet that was bigger than a small spider (although some kind forum member has been guiding me through it!). Once I figure it out, I'll post some pics.
soozieq, would you mind saying a bit more about isolation and microphonics? Is isolation on par with other canalphones like the CX300, or does the ported design of the ATH-C700 reduce it even further? Is music drowned out by the sounds of the trains/planes/buses you mentioned, or do the C700s still afford enough isolation to enjoy each part of the frequency spectrum? |
The cord/earpiece design seems to suggest that over-the-ear looping is not really possible (at least not sustainably so) -- Can you in fact loop the cords over your ears without them slipping off? If not, how microphonic do you find them when worn hanging straight down while you're in motion? |
Also, my stock question: Do you find them at all harsh or sibilant? |
