D0Hbert
- Sep 8, 2005
This happened to my Acmee MF01 after the C update. I emailed Acmee about it (they’ve been on holiday) and they sent me a .bin key. Basically, you put that in the root directory and the player goes back to normal. Email them and get the key. I don’t know if it’s a security thing or registration thing. But, don’t fret...
Haha. Me too. Luckily, Acmee responded right before Penon Audio. Was unaware that there was a holiday last week in China. But, both responded as soon as they got back.Appreciate the comforting words. Was about to initiate a refund on this.
On the other hand F.Audio XS-03 has a useless balanced output, because it is 3.5mm. Has anyone seen a balanced 3.5mm connector? Because I'm still looking for one, or at least some converter. I only recommend it if you like brilliant sound without bass. I had a lot of hope in that DAP, because I have the FAudio S1 that I love, for its sound and battery life, despite the flaws it also has, including a slight drop in bass, but only 2dB.
Hi all,
For someone who doesn't care about the internal amp (because they'll be bypassing it anyway), how do the Zishan's compare to the Acmee mf-01?
When it comes to the Zishan T1, is it better to have a single 4497 or a dual 4493? And could one use the balanced 2.5mm as an unbalanced LO? Finally, how does the T1 4497 compare to the DSD (besides the fact that the DSD appears to have a 3.5mm LO)?
well the DAC IC used in the DSD looks better in the datasheet.The DSD is the only one that works as a DAC with your computer (as of now). The others have not upgraded their firmware yet to be useable this way (although there are promises). When the firmware gets sorted out, the Acmee will be a contender. I like it a lot.
Edit: The T1, although touted as “swappable” DAC chip section, doesn’t really. Work that way. Also, I’ve already broken mine as I snapped the screen and that has caused it it completely be useless. So, longevity might be a problem with that one.
I’d recommend the Blon BL-03 with these type of players. A good inexpensive but great sounding single Dynamic driver. I get better results with a single and/or earbuds.well the DAC IC used in the DSD looks better in the datasheet.
Looks like will purchase a DSD then and maybe some earphones too
Where you guys recommend to purchase it? i see some sellers in Aliexpress that have it (and have earphones)
Thanks, looks like is my budget range, i have in mindI’d recommend the with these type of players. A good inexpensive but great sounding single Dynamic driver. I get better results with a single and/or earbuds.
AK KZ ZSX
CCA C12
ZhiYin Z5000
T2
and now Blon BL-03
I just have a pair of Vsonic GR99
Can you clarify what you mean by not swappable?Edit: The T1, although touted as “swappable” DAC chip section, doesn’t really. Work that way.
