UntilThen
- Jun 16, 2015
I had asked to have it removed. No power light for me.... Just tubes!Ok, first complaint. The power light is white! Ugh. Turn off the lights and it is impossible to see anything else. My gear is in front of me and so it is just blazing into my eyes. Why is a light needed at all? If an indicator is needed why not a small, dim red one? I’m going to have to figure out a way to cover this up. Hopefully it won’t be too ugly with the lights on.
I’m sure there are plenty of options. The mounting hole is 8mm. Get a 12V LED. Personally I like white as it’s cleaner looking. My reasoning for a pilot light is I like to know instantly when I flip the switch that the amp is ON, and not have to wait for the tubes to heat up.Yup. @SonicTrance is there a red light that can replace the stock one?
Oh, the amp is dead quiet and runs pretty cool so far.
I also like traditional Indian music, have you any titles like this you could post? I have quite a few classical guitar albums if you're interested.I listen to a wide variety of music except pop country and hip hop/rap left me behind around 2005 or so lol. My typical late night listening has been Indian classical music recently but I do also enjoy classical guitar and piano as well. First music using the amp is Andrew Bird’s album My Finest Work Yet.
I was concerned about this when I got my amp but I needn't have worried, it sounds fine.... Keep in mind that multi driver speakers with passive crossovers present a much more complicated load than single driver headphones.
Maybe it would be better to disconnect mine. That should be pretty easy to do right? That would save me from covering up the light and messing up the looks.I’m sure there are plenty of options. The mounting hole is 8mm. Get a 12V LED. Personally I like white as it’s cleaner looking. My reasoning for a pilot light is I like to know instantly when I flip the switch that the amp is ON, and not have to wait for the tubes to heat up.
White looks good when there’s light in the room. In the dark it is blinding. I can’t luxuriate in how good tubes look lit up! On a more serious note white light ruins night vision. When I look away I can’t see anything at all for a bit. It is also going to make it more difficult to see if there is any plate glow as I play with voltages. I will look for replacement LEDs. Are there different kinds of mounting options I need to look for?I’m sure there are plenty of options. The mounting hole is 8mm. Get a 12V LED. Personally I like white as it’s cleaner looking. My reasoning for a pilot light is I like to know instantly when I flip the switch that the amp is ON, and not have to wait for the tubes to heat up.
It would have to be pretty opaque but it’s a thought. A friend of mine ended up using black electrician’s tape cover up a blue LED on one of his amps. Blue is the absolute worst color for this sort of thing. It stands out in the day and absolutely bores holes into your skull at night.You could also just cover it with a decal of some sort. Maybe one of these?
https://www.redbubble.com/shop/vacuum+tube+stickers
What you need to take into account is that the front panel is 10mm thick. So you need a long threaded light holder. Mounting hole is 8mm.White looks good when there’s light in the room. In the dark it is blinding. I can’t luxuriate in how good tubes look lit up! On a more serious note white light ruins night vision. When I look away I can’t see anything at all for a bit. It is also going to make it more difficult to see if there is any plate glow as I play with voltages. I will look for replacement LEDs. Are there different kinds of mounting options I need to look for?
