UntilThen
- Jun 16, 2015
You showed me yours...
I'll show you mine...
Like 2 kids in a school yard right?
@senseitedj I am thinking of having impedance(s) switch on my Telemachus. Now that you have it, do you find it beneficial? What are the impedances you can set it to? Were you given the power output for each of the impedance?
That's a lot of questions.
Went to an audio exhibition in Indonesia and had a chance to demo a few pieces of gear. Link below are my impressions in the ZMF amp thread, as I tried it mostly with ZMF headphones. In particular I was curious with Atrium. I left some picture of tube amps in this thread. Got to try DCA expanse as well. Sounds similar to HEDDphone but with less soundstage but more comfortable (and expensive). DCA provided slightly higher clarity and soundstage still feels out-of-your-head.
I think if you are curious on demoing the Telemachus, there are some differences, but the Cayin HA300 MK2 provides a sufficiently good impression of what it sounds like. In general, the Telemachus has higher clarity, soundstage and generally feels a lot less congested-sounding (when evaluating under show conditions). To my ears, the 'voicing' are along with the same lines when comparing the Cayin HA300 MK2 with Telemachus on SS rectifier.
https://www.head-fi.org/threads/the-un-official-amp-thread-for-zmf-headphones.965309/page-35
It is a really useful feature, especially if you have multiple HPs. Mine is adjustable to 3 levels, but other oblivion owners have it to 2. I do not know the exact value of the output impedances, as I did not specify it in my build and just said what my main HPs, which are the LCD-4z and HEDDphone. I just let Tomas @SonicTrance work his magic based on that info. Perhaps he can comment.
I use HEDDphone on High-Z, and LCD-4z on Low-Z. High-Z on HEDDphone improves dynamics, punch and slam at a small expense of soundstage. No hiss or hum for LCD-4z even on high-z but I prefer to set it at low-z to improve its rather small soundstage. You can perhaps use it to add an extra degree of customisation on top of tube rolling.
I think each successive impedance level triples the power output, based on how it is implemented on the oblivion (see bottom): https://ultrasonicstudios.org/oblivion/ . But I cannot say this for sure
Ironically on my Odyssey, I prefer it on the HEDDphone on the low impedance setting (8 ohms). At 32 ohmS for it, I feel, only increases the hum.It is a really useful feature, especially if you have multiple HPs. Mine is adjustable to 3 levels, but other oblivion owners have it to 2. I do not know the exact value of the output impedances, as I did not specify it in my build and just said what my main HPs, which are the LCD-4z and HEDDphone. I just let Tomas @SonicTrance work his magic based on that info. Perhaps he can comment.
We use totally different amps so it's normal that the changes from the impedance are not the same.Ironically on my Odyssey, I prefer it on the HEDDphone on the low impedance setting (8 ohms). At 32 ohmS for it, I feel, only increases the hum.
I also have an attenuation switch, I find it does alter the characteristics - especially base and vocal forwardness.
What cables do you use with the HEDD?
So for you the LCD-4z is less sensitive to hum than the HEDDphone? I didn't expect that because of the HEDD's sensitivity of 87 vs. 93 of LCD-4z. Is the difference very great? I have a used HEDDphone incoming that I will try.I use HEDDphone on High-Z, and LCD-4z on Low-Z. High-Z on HEDDphone improves dynamics, punch and slam at a small expense of soundstage. No hiss or hum for LCD-4z even on high-z but I prefer to set it at low-z to improve its rather small soundstage. You can perhaps use it to add an extra degree of customisation on top of tube rolling.
A modest bit of the buzz also comes from the tubes, so I wonder if anyone has tried tube absorption rings to any positive effect?
