First off, though I may disagree with some of the folks here on certain things don't assume I'm directing any particular comments at you personally. Those whom I've talked to should know that straight away. For some others, this isn't the case.
Lol, CAD was actually very much a 'thing' 20 years ago. But you don't want to go there w/ F1 or any thing automotive related and do this dance with me, believe me. PM me and we can discuss inverted aerofoil heatpumps all day long. I only mention it as the head Objectivist likes to display his limited grasp on the subject quite frequently. I hear it's watches these days.
Either way, physics is the same then and now for cars and audio, that was the point irrespective of technical progress. For some reason many of the audio 'objectivists' here don't seem to believe in progress and further research like most scientists in the real world. Likely a combination of internet armchair quarterbacks who have never spent time in a laboratory before and EE's that spend more time implementing known designs rather than conducting research. There isn't a true scientist in the world that would strut around like some here do.
Consider the false premise that because we have mechanical and electronic gear that can measure beyond certain audible limits that many people here seem to take that to mean that this same measurement gear accounts for everything the ear and brain hears or perceives. Sloppy logic. That's an assumption many here make that you seem to have made as well. The O2 displays ideal performance under the metrics established and accepted by many here. Yet, with performance defined as ultimate transparency and wire w/ gain, the performance still falls short of other amps cheaper, equal to or more expensive than it though it does exceed many 'bad' or worse amps. I'm not going to repeat which amps as those that bother reading will likely know which I refer to already and those that don't bother reading, for whatever reason, aren't worth repeating for. Clean power delivery is superb for the price and size of the O2. Transparency is only okay though and only great if compared to poor amps as reference. Transparency being the ability to render or let whatever is on the recording or source pass through. Despite the 'ideal' measurements clung to here, the O2 does not meet or exceed the best amps available and still leaves out some information on the recording. So maybe somebody should ask why and figure it out rather than resting on false laurels and the illusion of epistemological omniscience.
While we're at it, let's examine two things. First, V claims the O2 in not discernible from the DAC1 from his tests. Let's see the Youtube video of him and Nick Charles conducting his own challenge to support his claim. A claim which is basically a summation of all his claims and work thus far. He can submit his transducer, source and track choice to me or purrin for approval as well as Nick Charles' methodology to ensure listener familiarity and listening fatigue reduction protocols. He can even keep his money in his pocket or donate it regardless of his own challenge and its outcome.
Second, I'd like V to ask the designer of the Benchmark DAC1 whether he thinks the O2 sounds exactly like the DAC1 HO. If not, why? What did V do wrong that his measurements failed to account for? If it does, then how does he explain V meeting his products performance for so much less than his likely costs and market price? With the ODAC and O2 being perfect wire w/ gain and transparent beyond audible limits, why would anyone want or need a DAC1? I'd tune in to the blog for that interview.
