Shazb0t
- Dec 25, 2012
I just want to save the socket on the o2. Sometimes the headphone cable gets stuck in the jack caught on the pin.
The headphone out is tight indeed. Get yourself an extension cable. They work great and no messing around unplugging anymore. I don't know where you are located but Monoprice has them for under $2 for the 6ft..
And no, they don't degrade the sound in any way.
Were the links supposed to be given in support of what you wrote or an unrelated issue?
That kind of impedance is pretty rare for a cheap cable, particularly if we're talking about short lengths. And even then, you might need a multi-BA IEM with a crossover to actually get non-trivial frequency response deviations (which are not the only possible changes, but probably the most significant ones). That's the only issue covered by the articles.
An extension cable can certainly degrade sound quality... I guess you haven't heard a crappy cable for 1 dollar or so? Try it out ,-)
My rule: The less, the better (on both software and hardware level). Therefore avoiding any redundant part of my audio chain, including cables and adapters...
Hi guys, two simple question:
- Can I use the O2+ODAC (I'm talking about the "single" solution, not the separated one) only as DAC? (es. source->O2+ODAC(only used as DAC)->AMP->Headphones).
- Can I use the O2+ODAC only as Amp? (es. source->DAC->O2+ODAC(only used as AMP)->Headphones).
I think I read somewhere that the first case is possible, but I don't know about the second one.
Thanks.
Both is possible. Buy an O2/ODAC desktop combo from Mayflower Electronics and want RCAs to work as outputs - that way, you have 2x RCA output from ODAC (you bypass the amp) and 1/8 input to the amp (you bypass the DAC).
With ordinary combo unit, you only get 1/8 input to O2...
Is there an EU store that sell an O2/ODAC combo with the same mod? (I don't want to pay extra-taxes, I live in Italy)
http://www.headnhifi.com/
That's the only EU store I know and use.
