- Feb 23, 2011
Ah, thanks for the information. I read somewhere that the Leckerton was preferred over the O2. I also read that the Leckerton offers better detail retrieval over the O2.
Kind of related to the O2, John of JDS Labs said their new portable amp, the C5, should sound as transparent as the O2. I pre-ordered one, so I guess I'll make a comparison between the two if I can hear any differences.
And I just realised I said the UHA-6S in my previous post when I meant to say UHA-4, the portable amp. XD
Quote:Does anyone here have experience with the Leckerton UHA-6S? I'm curious as to how it compares to the O2 as a more portable option.
Not me, but I seem to recall that some of the pirate crew (purrin, Anax, maybe others) had heard both and preferred the Leckerton. Of course, these are the guys who think NwAv's getting money under the table for the O2 / ODAC.
Seems like Mr. Leckerton quite knows what's up, is an application engineer at Cirrus. UHA-6S MKII uses a high-end Cirrus Logic DAC. There are some measurements of the older version published on the site, not completely comprehensive, but let's assume the rest checks out too. According to the objectivist camp and so on, there probably shouldn't be a discernible difference in sound between the two devices, operating at levels before clipping.
So at least by the specs, the limitations compared to O2 / ODAC are:
O2 gets 353 mW @ 15 ohms, 534 mW @ 33 ohms, (interpolated by me) 272 mW or so @ 100 ohms, 94 mW or so @ 300 ohms, on a mid-high charge on battery
- limited to 16/48 over USB (but there is an S/PDIF input)
- lower output power levels — 30 mW @ 16 ohms, 55 mW @ 32 ohms, 110 mW @ 100 ohms, 55 mW @ 300 ohms (presumably with stock output op amp)
So the O2 is better for some planar magnetics, maybe AKG Q701 if you listen really loud. Otherwise, no lower-impedance sets actually need that kind of power. O2 is also a little louder for high-impedance sets.
Supposedly the older UHA-6S has higher noise than the MKII, and even though there's no noise level listed, you can look at the spectrum on a THD+N spectrum graph for the original UHA-6S and see most of it around -145 dBV or so, whereas the O2 is around 5 dB quieter across the band. So at least the amp portion is really really quiet, good if you use some super-sensitive IEMs.
Listed battery life is better than that of the standard O2.
