KontG
- Apr 5, 2008
3-5 days delivery is really good for Europa from China
Originally Posted by psc001 /img/forum/go_quote.gif I just start to wonder if Octavart would think about including USB input instead of the optical since so many Dac/amp out there are including USB input. |
Originally Posted by mojolo /img/forum/go_quote.gif nevermind on the shipping costs from head-direct. jasmine_chine has it for $250 + $30 shipping! also, they offer an optional USB to optical socket for $10, but no idea of the quality of this unit. now just need some details on the DAC. HiFlight - you mentioned that you've used the D1 DAC feeding the octavart amp a lot. is this b/c the D1 has a better DAC? |
Originally Posted by HiFlight /img/forum/go_quote.gif No, it is because I was feeding the D1 with a USB from my computer that I wanted to run into the Octavart. IMO, there is nothing at all wrong with the optical and coax DAC in the Octavart. It sounds excellent. |
Originally Posted by mrarroyo /img/forum/go_quote.gif I opened the Octavart (O1 Amp/Dac) and it uses a Burr-Brown PCM1716E. |
Originally Posted by ILikeHeadphones /img/forum/go_quote.gif I'd still like to know how to select the source of sound. I'm guessing its like the ibasso D1. I understand the ibasso auto cycles through the different inputs until it finds a signal. I don't quite understand why there wouldn't simply be a source select button. If this is true, I guess I'd have to unplug/plug stuff in as I use it. So what happens if two things are plugged into different inputs at the same time? |
