The "re-appreciation" might start off with gettin' the TDA architecture right .... no, I ain't talkin' bouts da Bitstream 1990s models. I iz talkin' bouts da classic multi-bit y'all are so Jonesin for.
@]eep and @sajunky; thanks for the advice on bypassing capacitors. I finally got around to doing it with my 47 Labs clone, and it sounds fantastic! It makes its $30 cost (without PSU) all the more impressive.
I have some more wire coming, then I am going to bypass the caps on my other TDA DACs.
Ok @sajunky and @]eep, I bought another one.
It looks like there are resistors along with capacitors on the output. Should I bypass the resistors too? Or just the capacitors?
This is a bit of guessing and from memory, the 3 R and 2 little caps after the chip should go, except the middle resistor. On mine the values were 680R, 390R and 680R, the 680R plus cap handle the analog low pass filtering from about 15k (CR to ground). The big elco's (10uF?) near the output are the output caps and can be shorted or bypassed. The 2 R after that are most likely the resistors shorting to ground (2k?) and are necessary. So in short you could measure from leg 6 and 8 to output L+R should be uninterrupted and only one R (per channel) to ground just before the output. I don't remember what the middle R does in the analog filter but I remember vaguely desoldering it and it stopped working so leave it.
It's easy to change caps. I wish obbligato caps were still made. I can't find them anymore. I found a good replacement for speakers though. For electronics I prefer ye olde paper in oil capacitors.
At the other end of the scale, I’m still impressed by the performance of the ultra-simple TDA1543 implementation in my Hifiman HM-601Slim and HM-603 DAPs!
The former has recently had its battery replaced .
