eahm
Previously known as jHoNDoE
- Jul 17, 2010
The magic comes when you try AAC or Opus and you go down to 64kbps with some songs and you don't hear the difference with good headphones. Then you cry.
I'm assuming that the higher ohms just resist the hissing noise more
thank you for this post, it was just what i was looking for. id like to add a related question, if i may.
would the Impedance make any difference? i know that whether or not Impedance makes any difference at all is also a source of much debate, but still, would a higher Impedance be less "forgiving" and make the difference more apparent? would finding these small difference between bitrates be easyer with 250 ohm cans? how about 600?
This is a constant noise though, not for "artefact hunting". There's no reason I can think of for one headphone to be more revealing of compression artefacts than another.
can somebody please tell me if this site's test is accurate/fair?
http://mp3ornot.com
Anyways, I have tested this on my Computer + Asus Xonar STX and iPhone -> FiiO E11 using both the Monster Miles Davis Tribute, Monster Turbine Pro Gold, Beyer DT770, and Beyer DT990.
errrr.....do u think a dedicated dac would help u separate between the diff resolution?
Yes it is.
I found some level difference (a few tenths of a dB) between the pair of files I downloaded.
Edit: I tried another pair of files, and the 128 kbps version is again slightly quieter.
