RoninChaos
- Jan 21, 2016
Thank you for the reply. Any suggestion on a RCA switcher?The easiest way to do this with the analog outputs would probably be to use an RCA switcher. Connect the Modi's RCA output into one of the RCA switcher inputs, and then the RCA switcher output to the amp's input. Then, connect the other various devices to the RCA switcher, using 3.5 mm-to-RCA adapters as needed. Since some of those are portables and I imagine they'll come and go, then it might be enough to have a two-input RCA switcher with one 3.5 mm-to-RCA cable hanging out of it that you move from one device to the next.
You can also consider connecting the Modi directly to at least one of those if you want. The Steam Deck, at least, will have no problem connecting to its USB input.
Thanks!
