crazyhank
Oh so still a chance to buy?Not quite. There are still 50 left from the launch edition. They haven’t been built yet but when they’re ready they will be for sale through the usual channels.
External amp scales the Singularity quite bit.Thank you very much !
One last question: what about drivability ?
I wonder if my HiBy R6 Pro II will be able to drive it well.... (383mw )
The Singularity to me is a fantastic set whereas Meteor is the first set I really didn't appreciate much (I own Helios/ Singularity; heard Storm, Doublearity proto and pentabrid and enjoyed these all).How does it compare to the Symphonium Meteor, another set that Nightjar’s been involved in
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
I haven't. I'm sure it's great.Thanks, very useful. Have you heard the Crimson?
Started using Coreir tips yesterday. Sounds best so far and now is better able to stay in my ears.I've been using the Coreir brass tips on my Singularity for the last week and I'm really liking the pairing. Finally found an iem whose fit is not compromised by this tip and the effect of the brass hollow seems to bring a crispiness to the notes making them hit harder with more authority. I think this works!
Would you say that size wise they are the same as others? If I usually wear L for pretty much all manufacturers, is that what I should order for Coreir? I’m tempted to order ML just to try and see if it’s an even better fit.Started using Coreir tips yesterday. Sounds best so far and now is better able to stay in my ears.
I am using Large, but like you, I also want to try ML.. a search reveals that there is no such size for them. I ordered a set of M to see if they fit better.Would you say that size wise they are the same as others? If I usually wear L for pretty much all manufacturers, is that what I should order for Coreir? I’m tempted to order ML just to try and see if it’s an even better fit.
I am usually ML-L, so I bought M and L. But the M doesn't seal for me.I am using Large, but like you, I also want to try ML.. a search reveals that there is no such size for them. I ordered a set of M to see if they fit better.
Add an external amp to RS6 and the Singularity goes to another level.I had u12t in the past. I didn't keep them long struggling with fit .
Also I found nothing special to these IEMs maybe because of the fit (what a strange nozzle). Quite boring actually.
These singularity have nothing to do with U12t: bassy, bold, muscular sounding, engaging . This is how I'd describe these Nightjar (with Hiby Rs6)
I see some people like myself will much prefer the Singularity. Some others will much prefer the U12t
so if you love your U12t , not sure I'd replace them with Singularity. If you seek for sthing different then yes but good luck to find 1 set for the moment.
Thanx!I had u12t in the past. I didn't keep them long struggling with fit .
