And as for audio quality, these are for convenience over sound quality. Probably best bud I've heard yet but not even close the the BT audio with my BTR7 connected to one of my premium IEM's (as you would expect).
I too used the spinfits for the XM4 right out of the box. I never even put the included eartips on to try first. Did you try the tips that came with the XM5?
Can anyone test the Bluetooth volume on the A307 vs A306. Or A306 vs another Bluetooth device. I just to make sure I’m not imagining it lower on the A306.
I’m using the NYX+ on LDAC and the utws5 without LDAC so aptX HD on the A306.
on my capped 306 the volume using sony WH-1000XM4 using ldac is loud on both the sony walkman app and android apps (streaming etc).
however ive got some jabra elite 75 that are loud using the sony walkman app but very quiet using android apps like tidal etc. these dont use ldac
maybe that is the issue? i dont know but its very strange as theyre both using android and bluetooth volume is not meant to be capped so ive got no idea what's going on with the jabras.
ive got a d2. recently i bought an ibasso dx170 and a sony a306. of those two i prefer the sony. however the plenue sounds slightly better i reckon. theyre very similar but the plenue has a fuller lower end (in a good way) is how I would describe it.
i also prefer the cowon player app over the walkman
its sad cowon have gone under as i would definitely have bought an iteration that allowed streaming apps as well
When using the UTW5 (aptX adaptive) I can max out the volume but increase it substantially more on the ear hooks device itself. This takes it an unbearable level.
When I use the Svanar Wireless over LDAC I can easily max out the volume on the device. Since it has no volume control I can’t increase it more but I doubt HifiMan would be able to sell more than a couple of these earphones if that was the max output.
Seems like I am getting an opposite issue to yours where high res streams over LDAC are not as loud. I’ve tried DSD and others but all low over LDAC.
Perplexing to say the least. I bought this device to play music using LDAC at the gym.
On a separate note you are saying that TIDAL is not giving you LDAC. LDAC if I am not mistaken is the Bluetooth codec used and you could stream Redbox or 24bit and it wouldn’t t make a difference to LDAC. The quality would change but not the codec though it may be overkill.
Same as others have mentioned with me. Using Roon ARC requires higher volume setting than the walkman app. This is with the Sony WF 1000XM5 on a capped A306.
I received my new WF-1000XM5s a couple of days ago and have been using with my A306. I cannot get LDAC 990 to work smoothly even with the A306 in my shirt pocket (i.e. quite close). Has anyone been able to get reasonably solid connections at 990 or am I expecting too much?
I just connected my Svanar Wireless to the AK SP3000 and played Carbon Dioxide by Fever Ray at max and it was unbearable.
I then connected the Svanar Wireless to the A306 (capped) and full volume on the same track was at the fun level for me and I would have liked to push it more but the Sony limited it.
IMO the volume maxed on the Sony was about 65% of the max output I got from the AK.
Cap should not make a difference to bluetooth and this is really annoying making LDAC unusable for wireless earphones.
In both cases I used LDAC and the track was a master recording on Tidal.
To me this is strongly suggests that Sony is limiting the bluetooth volume output over LDAC.
I don't have the option screen in front of me but from what I recall the highest ranked version of LDAC simply wouldn't work so I selected the one below it. There were only 2 options for LDAC.
OK. I think you mean connection preferred in the bluetooth settings (not the Developer Options). That seems to pick LDAC "best effort" adaptive. If you pick sound quality preferred, it is 990/909 kbps which is near lossless for redbook audio, but it's not really usable for me, even at short range.
