emilsoft
- Dec 5, 2014
much more linear now, although not perfect.
Some tests on the EQ (+10 on 31hz band:
Great - that means at least a 4x unfolding (from 48KHz 1st level)Well, I have some actual MQA files that do show as 24/192 in Walkman Music app which is good enough for me. I can't tell a 96 vs 192 track.
Actually, think I got mixed up with 192/24 FLAC files.Great - that means at least a 4x unfolding (from 48KHz 1st level)
i saw a review where the player had a rubber stopper in the usb port but mine didnt have.
does anyones here? im not bothered tbh but if its meant to have it then i wonder if my unit was a return
Japanese ones (mine) has rubber stopper. I also use one in 3.5mm port when not usingi saw a review where the player had a rubber stopper in the usb port but mine didnt have.
Probably on Jap version has that. Mine didn’t . let your hair down, don’t use rubber - it’s more excitingi saw a review where the player had a rubber stopper in the usb port but mine didnt have.
Having one stuck in the 3.5mm and usb constantly might stretch out the holes a bit faster making them looser - not sure it’s for the bestJapanese ones (mine) have rubber stopper. I also use one in 3.5mm port when not using
Another updateActually, think I got mixed up with 192/24 FLAC files.
Just been through all my MQA albums and max show was 96/24.
for me its not bad. im 40 and have hearing loss prob off listening to cassette walkmans too loud and all the time from being a kid, thru ipods etc.I really don't know how you guys can use the capped ones.
They come as standard for both 3.5mm & 4.4mm with Japanese WM1AM2. One in mine is from the WM1AM2 I had (came with a spare).Having one stuck in the 3.5mm and usb constantly might stretch out the holes a bit faster making them looser - not sure it’s for the best
Another update
Found a 192 MQA album.
UAPP shows Master single unfold at 96
Walkman App shows as 192 but who knows if it plays at 192 or less
